speedometer compatibility problem.
Old Mar 1, 2002 | 08:03 AM
kranked91dx's Avatar
Default speedometer compatibility problem.
Here it goes again!!,
I got a d15b in my car, tranny got an electronic speedometer, My car is a 1991 civic DX Hatch, so the problem is that the speedometer type on a 1991 dx is usually Cable type, How can I hook me up a speedometer??? just add an external one??? anybody nowing a good brand ?? pics if possible ?
thank you
see ya
Old Mar 1, 2002 | 09:46 AM
SpooN Man's Avatar
Default Re: speedometer compatibility problem. (kranked91dx)
you can get a sir cluster. They need a electric vss. so you will be good.
Old Mar 1, 2002 | 12:39 PM
Default Re: speedometer compatibility problem. (SpooN Man)
you mean a JDM Sir Cluster from a 1991 japanese civic Sir??
Old Mar 2, 2002 | 07:04 AM
EGh22aEG's Avatar
i have the same prblem because i have an h22 in my ef hatch and i need to fine a gauge cluster to put in
Old Mar 2, 2002 | 11:37 AM
ruiner17's Avatar
Default Re: speedometer compatibility problem. (esp169)
yeah...personally i would get a SiR Cluster. They look much better and use the electronic VSS. I've got a similar problem, but just backwards. I've got an SiR Cluster with my Stock CRX Si engine. So i've got to drop in an electronic VSS in the tranny.
But yeah, the swap is fairly simple to do, just some wiring within the car...
Old Mar 2, 2002 | 01:32 PM
Bnjmn's Avatar
Default Re: speedometer compatibility problem. (ruiner17)
Anyone know if the 94+ VSS drops into the B series transmissions?
Thanks
Ben
Old Mar 2, 2002 | 08:14 PM
ruiner17 I was thinking about remooving the electronic vss, on my d15b tranny, will a cable speedometer adapter is made by someone ??
Old Mar 3, 2002 | 04:19 PM
Jaker's Avatar
Just use the cable drive from your original 91 DX transmission.
Old Mar 3, 2002 | 06:13 PM
Jared's Avatar
Like the guy above said, take the cable type speedo drive gear out of your old tranny and install it in the new one. fits with no problems.
93JDMHONDA
Apr 17, 2005 09:02 PM
bardo
17
Jan 25, 2004 08:07 PM
EF_LSVtec
Oct 6, 2002 03:45 PM
LB CRX
14
Aug 31, 2002 08:34 PM
