Mount studs
Old Feb 21, 2002 | 09:03 AM
97hb's Avatar
Default Mount studs
I am doing a b18b swap in a 97 hatchback. I was wondering about the driverside mount under the cam sprockets. Once you get the civic one off how do you get the studs out to put on the 99si bracket? I have the old integra one and tried to get that off (just experimenting) and it seems imposible. Am I going to have trouble getting the civic studs out? Also just looked at both ecu's and it looks identical (the pins) and it looks like I can just plug it in. I have already splice the crankfluctuation wire and evaporative purge, and everything else seems to plug in on the engine side. Do I have to rewire anything on the computer side? Thanks for all the relys
Old Feb 22, 2002 | 07:06 AM
97hb's Avatar
Default Re: Mount studs (97hb)
The alternator clip on the civic harness is a 4pin plug, on the teg its a 3pin. What wire is not used on the civic harness.
SoFresh1189
Dec 3, 2011 07:20 PM
88hondahatch
Feb 13, 2009 02:39 PM
Touch
40
Apr 17, 2006 06:38 AM
EvilCamaroSS
May 31, 2005 04:05 PM
ITR632
Apr 10, 2002 04:02 PM
