Confused, Need help on which a/c bracket to use!!?
Old Mar 19, 2002 | 07:44 AM
J_SpeC_EK's Avatar
Default Confused, Need help on which a/c bracket to use!!?
ok, i'm doing a b18c swap into an 97 civic ex coupe...i brought an a/c bracket from a guy that told me it came from an 99-00 SI.. it had a P-30 stamped on it.. On the hybrid site it says to use a del sol bracket instead of the 99-00 SI bracket. The picture of the bracket on the site, had a p54 stamp on it but it said it was a 99-00 civic si bracket.. SO what do i have ?? do i have a del sol bracket or a 99-00 SI bracket?? and which one do i need? the del sol or the 6th gen SI bracket? please help.. thanx..
the one i have has the P-30 stamped on it
[Modified by AzN_J_SpeC, 4:44 PM 3/19/2002] [IMG][/IMG]
[Modified by AzN_J_SpeC, 4:50 PM 3/19/2002]
Old Mar 19, 2002 | 08:52 AM
LXguy's Avatar
Default Re: Confused, Need help on which a/c bracket to use!!? (AzN_J_SpeC)
Hey:
I have a '95 Civic and '95 GSR motor, so if there is a change due to OBD stuff (which I highly doubt), what I have to say may not help you.
I got the P54 bracket for my swap, and it worked perfectly. My understanding when I ordered it, was that this bracket was from a DOHC Vtec Del-sol.
I too tried the P30 bracket and it did not work.
Here's my post:
https://honda-tech.com/zerothread?id=122003
Good Luck, hope this helps
Steve
Old Mar 19, 2002 | 07:06 PM
J_SpeC_EK's Avatar
Default Re: Confused, Need help on which a/c bracket to use!!? (LXguy)
ok,, so what i've gather from you other post,, i would need the p30 bracket for my swap?? i have the ek model of the civic, so i'm assuming i would need the p30 bracket, which i have.. any other info will be greatful.. thanx
Old Mar 19, 2002 | 08:43 PM
stockegsix's Avatar
i have this problem too, which bracket do i use? i have a 97 civic dx compresor should i use a p54 or a p30 bracket? also which AC belt should i use? (bought a 00 si AC belt) thanx
97 civic dx(all silver)
b16a2(odb2-obd1 conversion)
greddy evo
aem cai
Old Mar 20, 2002 | 02:46 AM
kenji's Avatar
25 Year Member
Default Re: Confused, Need help on which a/c bracket to use!!? (silversleeper)
If you are using the DX compressor and you you want to put a B-series swap in your EK you need to use the P54 bracket.
The P54 bracket is designed to run the 'Civic type' compressors.
Here is an interesting fact...the '99-'00 Civic Si uses the 'Integra type' compressor. That is why the '99-'00 Civic Si uses the P30 bracket just like '94-'01 Integras.
To answer your question...you need the P54 bracket. For the belt...you can use one off of a '94-'95 DOHC VTEC Del Sol. Or just find a belt that fits from your local auto parts store.
-kenji
Old Mar 20, 2002 | 06:54 AM
Kalokohan's Avatar
New User
I thought you used the P54 bracket if you had a B-series engine and using a 96-00 civic compressor and you would use the P30 bracket if you had a B-series engine using a 92-95 civic compressor? Please verify?
Old Mar 20, 2002 | 07:42 AM
J_SpeC_EK's Avatar
Default Re: Confused, Need help on which a/c bracket to use!!? (Guardson3r3)
yes.. that was my understanding too.. oh please someone verify this.. i'm realli to get this damn motor into my car!!
[Modified by AzN_J_SpeC, 4:42 PM 3/20/2002]
Old Mar 20, 2002 | 07:47 AM
stockegsix's Avatar
then p54 it is then, they have it at the junkyard in sun valley for $75 i'll get one thankx kenji...
b16a2 (obs2-obd1 convertion)
greddy evo
aem cai
racing hart cp8
Old Mar 20, 2002 | 07:54 AM
LXguy's Avatar
I should clarify and state that I used the Civic compressor in my swap rather than the GSR compressor.
The reason I did this was to avoid having custom AC lines made.
I would be willing to bet that the P54 is the right bracket for you, but make sure you buy it from someplace that will take it back.
Steve.
IMPATIENT
Mar 22, 2006 06:46 AM
yh23
Aug 10, 2005 11:16 PM
Fuster_Cluck
10
Apr 22, 2005 10:46 PM
jdm jedi
Sep 14, 2003 03:21 PM
