need help B16
This is all i have. The guy I got the motor from said I can use my D16 engine harness is that true? Can I use axles off a B16 99 civic si? What else do I need before I start? Can't wait to swap in my 90 civic....... thanks
[Modified by si foo, 11:12 PM 3/9/2002]
You will need 90-93 integra axles and a rear motor mount from the same vehicle. You can use your D16 engine harness but you will need to add the proper wires for VTEC.
You better hope your 90 Civic aint a DX...or else youre gonna go crazy with the Dual Point Injection harness...you better go get a 88-91 Si Wiring harness for ease of installation.
Also i would invest in an OHM meter and test the TPS senosor and the knock sensor! If these are broke, whitch they do in shipment can cause your car ot hesitate!!! You will need a 90-91 crx si wiring harness i dont know if the cx wiring harness will work. Also make sure when you replave the axles to be carfull of not damaging the axel seals. The JDm ones wear over time and may need to be replaced. We dripped one not knowing and had tranny fluid all over the bottom of the car and had to replace them after we figured out that the seals were gone!!!
if i swap the intake manifold from the B16a2 i have to run OBD2??????
can't i use the ac and the factory brackets from the B16a2 to fit in to the SIR?
i figure that most parts are interchangeable between the two motor besides the electical part cuz of the non OBD and the OBD2 ... I'm lost now. here the second motor I have which is the B16a2..
[Modified by si foo, 9:24 PM 3/11/2002]
