HELP: Just put in new motor and....
I just swapped in my new motor. Anyways...I pulled it out to take it for a spin.....and I get down the block...shift into 2nd and it stops working. Also now that it dont move....when I step on the gas the speedo kinda climbs also. SOMEONE PLEASE HELP . Thanks
Re: HELP: Just put in new motor and.... (CivicEK.PDX)
If the speedo is working and the car does not want to move when you press the gas with the car in gear you might have a problem with your differential.
Please keep in mind that it is difficult to diagnose problems via the internet. This may not be what is happening in your case. But, from past experience the symptoms you described indicate something wrong with your diff.
Good luck.
-kenji
Good luck.
-kenji
sounds like the axles r not in the tranny housing all the way. speedo climbs indicating that the diff is movin but the car isnt. axles axles axles.
Re: HELP: Just put in new motor and.... (hondaatwsu)
DAMMIT........it was the axle.....pulled it and it was sitting out about 1.5 inch. About 2mm was taken off the inboard part. Diff looks fine( found some metal shaving.......but wiped them out......but it looks fine) just the splines on the axle are gone about the ring. Waiting for axle right now.....and gonna give the tranny a fluuid change.
Oreo-TeCk
07-01-2007 10:33 PM
memorybox
11-23-2006 05:08 PM
