exedy flywheel install HELP!
I've never personally installed a clutch/pp or flywheel before, so on the flywheel install, is there anything I should watch out for? I've pulled motors and removed trannies, but are there any potential problems that I should be concerned about? thanks in advance..
its pretty straightforward
i did my first one while my motor was out of my car
the only peice of advice is get a clutch alingment tool from autozone or somthing
other than that its simple
just make sure you torque everything down to honda specs.
[Modified by KAMiN, 7:38 AM 3/7/2002]
so since i'm pulling out the clutch/pp/flywheel assembly, I'll need to align it back up via shims(?) or something to that effect, and the alignment tool will assist me in doing so? I haven't read the Helm's or Haynes I have concerning this, just wanted to get your guys' help before I dive in.. thanks again
