ls/vtec lazy
Old Mar 16, 2002 | 12:16 AM
Top_spec's Avatar
Default ls/vtec lazy
it seems as if my lsvtec runs really hard when the car has been sitting for about 2 minutes and then after running it hard it starts to feel lazy could it be my fuel filter or fuel pump
i just put in h22 injectors and it made a big difference than before but it still does it
Old Mar 16, 2002 | 06:05 AM
speeddave's Avatar
Default Re: ls/vtec lazy (Top_spec)
what size are your injectors and what do you control your a/f with?(v-afc/fields etc)?
Old Mar 16, 2002 | 08:33 AM
Top_spec's Avatar
Default Re: ls/vtec lazy (speeddave)
there just stock h22 prelude injectors i dont have anything to control them i do have a mugen computer chip tho
Old Mar 16, 2002 | 01:54 PM
speeddave's Avatar
i'm not an expert on this so i am giving you my opinion on what i think is wrong...if you have the h22 inj, there is a good chance that those coupled with the mugen ecu(which already runs rich) are making your ls/vtec overly rich. check the plugs, see what color they are...this will give you a good indication of how rich/lean your engine is. i think those inj are 330-340cc which are quite large and should be used with some sort of tuning device. hope that helps...
also as a side note...when asking a tuning related question it helps to list your complete setup, this helps people to get a better idea of what the solution might be, and they can help you better.
[Modified by speeddave, 10:56 PM 3/16/2002]
Old Mar 17, 2002 | 12:27 AM
Top_spec's Avatar
well the engine is pretty basic
stock pistons stock auto b16 cams
upgrading to gsr cams soon
and basically everything stock
o and 2.25 inch exhaust
Old Mar 17, 2002 | 09:03 AM
speeddave's Avatar
did you check your plugs? i would say your running very rich. since your combo is stock, low compr...i would say that your inj are too big.
Old Mar 17, 2002 | 10:11 AM
Top_spec's Avatar
i am gonna pull the plugs today so ill see if its running rich or not
Old Mar 17, 2002 | 06:44 PM
Top_spec's Avatar
pulled the plugs they look orangy brown
and i got my fuel pressure up to 42 psi
Old Mar 17, 2002 | 08:16 PM
speeddave's Avatar
how long have the plugs been in the motor? i would try the simple things first...fuel filter then fuel pump etc... the plugs should be black if it was too rich. i dunno, i still think h22 inj and mugen would make you rich. if all else fails you might have to go to a dyno. if you had some sort of a/f meter that would help things a lot. sorry man, i can't give you a definite answer.
YANG_JDM
Oct 26, 2008 07:56 AM
TYPErCRX
May 22, 2007 07:36 PM
dek1mfk
Dec 11, 2006 08:13 PM
dat_flip
Sep 17, 2004 12:47 PM
