hp differance b18b jdm b20b
Old Mar 16, 2002 | 02:26 PM
1stealthls's Avatar
Default hp differance b18b jdm b20b
which of these have more hp stock
Old Mar 16, 2002 | 09:15 PM
daver's Avatar
Default Re: hp differance b18b jdm b20b (MugenEg)
i've understood that the jdm b20b is identical to the usdm b20z. The latter of which has 146hp, compared to the b18b which is at 140-142hp. However, the b20 will have more torque throughout, and apparently when you slap on the integra intake manifold and other standard boltons, you'll end up with the fly equivalent of 160hp.
d
ps. what i'm still trying to confirm, tho, is if all jdm b20b years have the 9.6:1 cr pistons like the b20z's here.
Old Mar 17, 2002 | 02:56 PM
1stealthls's Avatar
Default Re: hp differance b18b jdm b20b (daver)
what year r the b20 with 146 and are they the same jdm-usdm
Old Mar 17, 2002 | 06:05 PM
daver's Avatar
Default Re: hp differance b18b jdm b20b (1stealthls)
here's a link with the USDM specs anyway... http://hybrid.honda-perf.org/tech/b20/b20tech.html
Initially, i had heard that all jdm b20b's (B's are all they have there) are the same as USDM b20z's. Then i read a post claiming that their '97/98 B's ARE the same as the b20b's here (lower compression, 126hp). I havn't been able to find absolute verification, either way, since then.
I have read tho, that in Jap they have the b20's in multiple cars, each with their own intake manifolds and tuning, resulting in different power figures. Even when the innards are the same.
d
Old Mar 17, 2002 | 06:53 PM
Ri5e's Avatar
The JDM b20B pistons are the same as the B20Z USDM. 9.6:1 compression.
Old Mar 17, 2002 | 07:37 PM
daver's Avatar
Default Re: hp differance b18b jdm b20b (BG Boost)
the '97 and '98 ones too, forsure?
Old Mar 19, 2002 | 08:19 PM
StorminMatt's Avatar
The JDM B20B is basically a USDM B20Z with the earlier 'giraffe' intake manifold. That is why power is lower. But sicne you won't use this manifold, the two engines are actually equal.
Old Mar 19, 2002 | 08:29 PM
daver's Avatar
Default Re: hp differance b18b jdm b20b (StorminMatt)
Are ther any sites showing the jdm b20b specs?
I had heard that they had that engine in many cars there; so had several intake manifold configurations...
d
Old Mar 20, 2002 | 04:18 AM
eg6ajk's Avatar
there are three kinds that come from JDM land:
CRV gets two kinds just like we do the difference is only in the intake but not in the compression
SMX wagon, gets a B20B with a LS intake/headers and other parts
on a dyno my buddys JDM B20B pulled:
138whp and 137lb/ft of torque all stock, running in an 93 integra RS, no mods anywhere....those things are monsters...
dezerte
Mar 10, 2007 03:12 PM
2NR0066
Feb 10, 2005 08:06 AM
spock_rocker
Mar 26, 2003 07:49 PM
baybeboi
Sep 18, 2002 06:51 AM
