hard time starting
Old Mar 14, 2002 | 12:43 PM
Top_spec's Avatar
Default hard time starting
yes hi ive just swapped a 94 ls motor into a 93 civic and it has a hard time starting for it to start i gotta spray intake cleaner in it and it runs off the intake cleaner then it starts to run properly
i think there might be somthing wrong with the injector pulses
Old Mar 14, 2002 | 02:41 PM
daver's Avatar
Default Re: hard time starting (Top_spec)
whenever i spayed intake cleaner into my engine, it would choke and almost die. You don't mean ether or quickstart?
d
Old Mar 14, 2002 | 09:56 PM
Top_spec's Avatar
Default Re: hard time starting (daver)
no its intake cleaner the reason why it does that to u is because u are flooding the engine
but it almost seems as if this car is carburated its like once its going its fine
i have a feeling it has somthing to do with the injectors
is there any type of resistor box on this car
1990-da
Nov 6, 2012 08:13 AM
mbulanov
Oct 10, 2008 09:22 AM
gduprice
Sep 12, 2004 01:03 PM
kotetu
Jun 17, 2003 07:23 AM
Turbo-Si
Jan 13, 2002 08:42 PM
