CRVTEC with CTR head and tranny?
Old Mar 13, 2002 | 11:49 PM
zhonda's Avatar
New User
Default CRVTEC with CTR head and tranny?
I fitted a B16B engine from a JDM CTR in my 6 gen hatchback, transplanted the whole lot, including engine, tranny, suspension, engine mounts, brakes etc, etc.
The next step in my project is a B20B block replacing the one i have right now, with the TypeR head, but i have a few doubts:
- Exact specification of the pistons i need in order to have correct valve clearance and still maintain a high compression
- Do i need to machine the combustion chambers to match the pistons bore?
- Do you recommend i use the B20B's connecting rods and crankshaft with the new pistons?
- Do i need to fit the oil squirters, if yes, which ones are appropriate and easy to fit.
- Can i use the B16B flywheel (would it fit the B20B without any mods?)
- Can i use the B16B axles? Any modification required?
- Anything else i have to pay attention to?? , like gaskets, clutch, any holes to be closed?
Thanx
Old Mar 14, 2002 | 06:06 AM
Trey's Avatar
25 Year Member
Default Re: CRVTEC with CTR head and tranny? (zhonda)
http://www.importbuilders.com
Jeff can answer your questions and sells what you need........
Old Mar 15, 2002 | 04:48 PM
Ruby Civic's Avatar
Default Re: CRVTEC with CTR head and tranny? (Trey)
a few things about the head - leave the size alone, Tom Fujita at Portflow says these do not need to be matched and use the standard b20 head gasket.
you can use same rods, but if you are going higher power why not just go Crower or likewise. valve clearance can be a prob even if pistons fly cut but usu like Arias, tell them and clearance is OK. You should ALWAYS clay the piston/valve combe to check for clearance.
i have a JDM b16a with Portflow head and CTR pistons and valves were fine but sparkplugs HIT!!!!! which is because of bowl work by Tom I had milled my head .030 to keep dame compression ratio.
i will let some others answer a few of your other questions.....don't forget that cam lift is determining the "push" of the valves so if you have a CTR lift of 11.5 mm and then go to a Toda of 12.0 mm you use up more clearance....
EK-R Hatchman
18
Jan 24, 2007 03:08 PM
Hazeburner
Feb 11, 2006 08:54 AM
92integraVTECgsr
Jan 10, 2006 07:44 PM
RICE POLICE SIP
Mar 9, 2003 12:25 AM
17secondcivic
Sep 7, 2002 11:21 AM
