Clutch Master/Slave Cylinder Compatibility Question
I need to replace my clutch master cylinder and my slave cylinder on my 97' Civic DX w/ B18C. I am assuming all clutch master cylinders are the same (94-00 Integra, 92-00 Civic and 97-01 ITR) as well at the slave cylinder except for the hard line that ties into it. Is this correct are they the same part # and can they bolt right up?
New User
Re: Clutch Master/Slave Cylinder Compatibility Question (B18CJDM)
not sure... but why do you have to replace the clutch master cyl and slave cyl? just curious.. i think i might have a bad master cyl.
Re: Clutch Master/Slave Cylinder Compatibility Question (supergreenSol)
i have a clutch master stage 4 in my car and shiiet! my master cylinder and/or my slave cylinder is jacked up. have no idea which one it is. but one of them is!
Re: Clutch Master/Slave Cylinder Compatibility Question (MugenGTR)
Re: Clutch Master/Slave Cylinder Compatibility Question (brian g)
d16y8 slave cylinder will not fit on a 92-96 H22A i know that the bleeder nipple hits the front mount .. wait let me say that again it will fit on there but what is wrong is the bleeder nipple so yes it is kinda compataible.. sorry if that don't make since
They are all compatible.
brian g
brian g
[Modified by B18CJDM, 2:44 PM 3/14/2002]
it might be different from ludes/accords as someone said before but as far as civics and integras goes, they're all the same. well, they all WORK the same at least. i have no idea if it's the same part number but i know for a fact that they will all work. i have a dc teg and i'm getting a master cylinder and a slave cylinder off my friend's wrenck eg civic.
siregcivic
10-16-2005 07:55 PM
