ECU help
I did a swap H22A to 97 civic hatch. Its running but it needs to be converted to OBD1. What ecu should I use? 94-95 Integra GSR, 94-95 Prelude, 94-95 Accord, Delsol (what year). Any suggestion on where I can get them?
if you have obdI plugs then a lude obdI ecu or 94-5 GSR ecu (JDM or USDM)
accord is meant for sohc vtec application (unless its JDM H22) and delsol at best has maps which do not provide enough fuel
also del sol ecu and most likly the sohc vtec accord do not controll the secondary butterfly on the intake...
if you are interested I have a 98 JDM GSR ecu ($200US shipped) it uses a OBDI programming (same as obdi but obdii plugs, with it i throw in a plugs and part of harness (basically unfinished obII to obdI harness)
I have a USDM H22A with a OBD2 plugs. I'm interested on your ecu but just to clarify things, the 98 gsr ecu had been reprogram to OBD1, right. And, who did the reprogram? Please email me nisnisan@optotech.com
3litre190
Jul 24, 2007 02:49 PM
