LS/VTEC??
Old Mar 14, 2002 | 04:20 PM
yellowcivic's Avatar
Default LS/VTEC??
LS/vtec ? is it true?? I heard that u wont get enough Valve clearance when u swap a b16 head on a ls block with ls pistons is that true? as well as they said i needed to throw in the B16 pistons in place of my LS pistons
Old Mar 14, 2002 | 07:21 PM
daver's Avatar
Default Re: LS/VTEC?? (yellowcivic)
"they" always seem to be wrong. According to all my research, the piston-valve clearance will be ample. As far as the pistons go. The ls ones will yield a low 9.6:1 cr and the b16a pistons pop the cr up to 11.5+-. They will both work.
However, i'm a "they" too. Do mucho research and talk to lots O people before commiting to somthing expensive like this contraversial engine build.
d
Old Mar 14, 2002 | 07:38 PM
Jackson's Avatar
i ran stock ls pistons with a b16 head with itr cams. valve clearance was ok. just dont plan on advancing the intake cam. you can always widen the ls valve reliefs, i have heard of a tool that will shave off hundreths of an inch off of the pistons.
Old Mar 15, 2002 | 10:15 AM
Default Re: LS/VTEC?? (Jackson)
which would be better ab route to go with ?
Ls pistons or B16 pistons??
Old Mar 15, 2002 | 10:24 AM
WAFFLES's Avatar
vtec pistons always
Old Mar 15, 2002 | 10:26 AM
daver's Avatar
I think they say that a full point cr increase will yield 7% more power (or was that 7hp)? More power with the b16 pistons (with higher octane gas too), but more wear and tear. Whatever you want.
d
Old Mar 15, 2002 | 10:32 AM
Jackson's Avatar
Default Re: LS/VTEC?? (daver)
stock bottom end with b16 head will give 9.53:1 compression
ls bottom with standard bore pr3 pistons will give 11.29:1 compression
ls bottom with standard p30 pistons will give 11.51:1
with usdm itr pistons 10.77:1
with jdm itr pistons 11.28:1
pr3 pistons and jdm itr pistons are pretty close in compression. if you are looking for a cheap piston, then get used b16 pistons. i used usdm itr pistons and they made good power over stock ls pistons. i would suggest itr pistons for your ls/vtec.
Old Mar 15, 2002 | 10:36 AM
daver's Avatar
just a curious question. Do vtec pistons have some strength or weight advantage, or is the recommendation just due to increased power?
d
Old Mar 15, 2002 | 10:57 AM
Jackson's Avatar
they used to increase compression which gives you more horsepower and the valve reliefs on top of the pistons are wider for the vtec valves. vtec valves are bigger than the non vtec ls valves, so you have a chance of hitting the pistons with the vtec valves.
HondaBurger
Sep 19, 2007 02:36 PM
1995sir
Apr 26, 2006 07:43 PM
1995sir
Apr 26, 2006 02:35 PM
stockb16hatch
30
Feb 21, 2006 12:42 PM
91civicDXdude
Jul 16, 2003 02:20 PM
