ECU Pins
Old Mar 13, 2002 | 02:26 PM
keebler65's Avatar
Default ECU Pins
i'm swapping a b16a1 into my 91 crx si and i am on the search for ECU pins for the few wires i need to add to my connectors. everyone says go to the dealer, so today i went over to acura and they knew what i was talking about but didnt seem to know if/where they had them. so i went across the highway over to honda and they said the exact same thing. i've also called around to local performance shops but have had no luck. besides a yard, does anyone know of a good source? i of course only need a few. all help is appreciated thanks!
Old Mar 13, 2002 | 02:40 PM
ALF's Avatar
ALF
Default Re: ECU Pins (keebler65)
http://www.ahmotor.com
They give much more helpful info than the dealer.
Old Mar 14, 2002 | 08:52 AM
keebler65's Avatar
Default Re: ECU Pins (Dozed)
i sent them an email but i guess they said it wont be answered for a week or so, i guess we'll see what happens....thx for the link
Old Mar 14, 2002 | 09:25 AM
EE_Chris's Avatar
I gave them a call upon reading this topic. The guy told me he doesn't have it, or know of the part number.
I'd also like to know this answer too.
I remember ALONG time ago, back on the real old Hybrid board, someone had posted a part number to this kit....I'll be damned if I can find it anywhere though.
Old Mar 14, 2002 | 02:38 PM
keebler65's Avatar
sounds like we might have to resort to the junkyard after all....
Old Mar 14, 2002 | 03:14 PM
kenji's Avatar
25 Year Member
Just go to the junkyard and cut some plugs out of a car.
If you get the pins from Honda/Acura you need to crimp on the wire. It can be done with any pair of needle nose pliers but it may not hold. You need a special crimping tool. Trust me on this one...
-kenji
Old Mar 14, 2002 | 03:52 PM
keebler65's Avatar
Default Re: ECU Pins (kenji)
i'm sure it could be soldered too
Old Mar 15, 2002 | 02:46 AM
kenji's Avatar
25 Year Member
Default Re: ECU Pins (anger)
Keebler,
You are correct in stating that you could solder it as well as crimp it with a pair of pliers. I have done this before and it does work. It is just time consuming. If you are only doing a couple of pins it is no big deal.
Good luck with what ever path you choose.
-kenji
Old Mar 15, 2002 | 05:16 AM
EE_Chris's Avatar
So kenji, do you know where to get NEW pins from (dealer, other source)?
Part #?
RedneckRicer
Aug 3, 2010 05:19 AM
hard_boiled_EG
Oct 15, 2009 05:16 PM
Master23
Sep 30, 2005 03:27 PM
mike84 CRX-GTL
Aug 12, 2005 06:46 PM
Da1spaz247
Jan 14, 2005 12:46 PM
