b16a in 00 ek
Old Mar 12, 2002 | 09:58 PM
boot machine 5000's Avatar
Default b16a in 00 ek
planning on swapping a jdm 2nd gen b16 in my 2000 ek. would i be able to use the obd1 distributor that comes with the motor or would i need a obd2 one? also would i need a new engine harness or can i use my stock one with some modifications done? also would i be able to use a p2t 99 si ecu with the motor. thanks.
Old Mar 13, 2002 | 06:30 AM
Inigo Montoya's Avatar
Default Re: b16a in 00 ek (ALVIN)
you may want to post this over in the hybrid forum. as for you question, I am unsure, i have a 98 so I am wondering the same
Old Mar 13, 2002 | 06:36 AM
rainforest's Avatar
Default Re: b16a in 00 ek (inigo9910)
you need the plug just from dist and repin the wire the exact color you see on the other side.
Old Mar 13, 2002 | 07:46 AM
Jackson's Avatar
if i were you, would get an obd2 b16a. if you buy an obd1 2nd gen, just trade someone for their obd2, yeah, you can change the plugs, but that is ghetto. swap all of your obd1 parts for obd2, get an si engine wiring harness. if you get an obd1 motor, you are going to get a code for ckf, which is on obd2 blocks, not obd1, unless you run an obd2-obd1 ecu jumper and run an obd1 ecu. you will also need to add a 2nd o2 sensor if you run the 99-00 si ecu with the si harness, unless you run an obd1 ecu. this is kind of a mess of info. if you have anymore questions, you can IM me or email me.
Tony
Old Mar 13, 2002 | 10:09 AM
Default Re: b16a in 00 ek (Jackson)
thanks tony i understand completely. yeah it would probably be easier to run an obd1 ecu with a jumper harness.
Old Mar 16, 2002 | 07:35 AM
o.G.A.g.'s Avatar
isnt it illegal to swap in a motor that is older than ur car?
Old Mar 16, 2002 | 08:09 AM
fowler!'s Avatar
Default Re: b16a in 00 ek (kb8)
in California, it's illegal to have a motor that is older than the car.
kaoticstyles
Jun 20, 2008 03:30 PM
NOman0608
May 12, 2007 08:39 PM
Cboi
Mar 26, 2007 04:57 PM
boostin4drcivic
Apr 30, 2004 11:40 AM
hatchy
Mar 31, 2002 08:24 AM
