weird h2b timing question
Old May 31, 2012 | 05:38 PM
aznfreakyguy's Avatar
Default weird h2b timing question
the basic question is:
Will the car (h22a1) run if the distuributor timing is set to 0 degrees, will the ecu compensate?
Back story:
My h2b has been running for about 7000 miles now, and i am now starting to mess around with tuning it. it was running the stock p13 before. i have checked timing before and i always thought that i had it set to 16 degrees. but i recently took off the cam gears and put them back on, so maybe i messed something up. the timing mark on the qsd h2b flywheel spacer is TDC right? my cam gears are at tdc with the flywheel mark are at tdc, so i think that is correct. when i go to check timing though..... the mark on the flywheel is at 0 degrees with a timing light, and thats with the distributor advanced all the way forward. car doesnt feel sluggish at all but it does take 7-8 cranks from a cold start before car starts. will the car even run if its really set at 0 degrees? or am i reading that one timing mark incorrectly...
Old May 31, 2012 | 06:24 PM
Default Re: weird h2b timing question
nevermind.... brain fart.... guess my working 6 days straight wiht only 5 hours sleep each night is getting to me, this thread can be deleted lol
*edit*
ok i think im way overthinking this.... its an adjustable timing light, isnt it suppose to set to wahtever degrees on timing gun, say 16 degrees, and that is checked against the tdc mark? so the gun is saying 0 degrees and tdc mark is lined up, doesnt that mean its on 0 degrees?
Old May 31, 2012 | 08:40 PM
SL0WEGG's Avatar
That's how I thought it was. You would only adjust it if you wanted to advance timing. But your dizzy shouldn't be advanced all the way.
Old May 31, 2012 | 10:36 PM
would the car even run if it was really set at 0 degrees? its been at this setting since i started driving the car i think..... the cam gears match the tdc mark on the flywheel so im not sure what else i can adjust....
tctruong94
Apr 27, 2017 11:10 AM
Jsarv
Engine Management and Tuning
Apr 1, 2012 01:48 PM
KeithsDAteg
Nov 29, 2009 05:32 PM
chitownrida
Sep 24, 2005 08:46 PM
