f20b swap
Old Jul 7, 2012 | 06:40 AM
96-wagon-boy's Avatar
Default f20b swap
hey watz up guys just looking for some opinion.... is it worth investing on a f20b dohc vtec blue top on a eg 4 door?
Old Jul 7, 2012 | 06:49 AM
Jap.Doe's Avatar
Default Re: f20b swap
you'd need to get am h2b kit or use an h/f series transmission, the mounts and wire up vtec. But you'd have a high reving blue box of fun lol. i was actually considering this setup for my Hatch, so i say go for it lol.
Old Jul 7, 2012 | 07:28 AM
lolz thanks soo that mean i can h/f series parts such as headers,cams, cam gears, intake manifold, piston........
Old Jul 7, 2012 | 01:27 PM
Golding.racing's Avatar
yep sure can
Old Jul 7, 2012 | 07:27 PM
so i can use the ecu from a h22a4? since its a obd2
Old Jul 7, 2012 | 10:37 PM
Jap.Doe's Avatar
you CAN, but the f20b revs higher than an h22, and has different compression as well, your engine wont be working right unless you get it tuned, or use the original f20b ecu. also you know theres two types of f20b's right? one auto and one manual. i believe the difference comes from the cam shafts and something else i cant remember. just try to order an engine that has the ecu lol
Old Jul 7, 2012 | 10:38 PM
Jap.Doe's Avatar
and yes all aftermarket parts for an h22 will work with the f20b since they'er pretty much the same engine.
Old Jul 8, 2012 | 01:54 PM
it a manual with a lsd
Old Jul 11, 2012 | 07:04 PM
hondasdohc's Avatar
I had one in my 4dr eg it was hella fast but water got sucked in the intake and messed up my rod bearing. It would just take off and rip first and all of second on the f22 trans with long gears chirping third on a stock seco clutch. I also had the auto version i think but the bitty moved. Oh and i forgot to mention it had two cylinders with low compression cause the head was warped.
Old Jul 12, 2012 | 07:48 PM
turbociv910's Avatar
had a h2b f20b with type r trans in 99 si.. fun!
Old Jul 17, 2012 | 04:30 PM
onpoint6's Avatar
1you cannot use the pistons or rods, and i dont think the crank either.
2the cams and header are already type s
Old Jul 17, 2012 | 04:31 PM
onpoint6's Avatar
have you seen the f20b rs ratio? its not good. i know it revs high from the factory but id still get a ls fifth just to be safe
Old Jul 17, 2012 | 11:34 PM
blwncr's Avatar
Are you for real? The only other honda engine that has a better r/s ratio is a B16a, its even better than a K20.
Old Jul 18, 2012 | 12:52 PM
onpoint6's Avatar
i stand corrected this is true. run a b16 tranny. sorry
ISUBIEXI
Dec 26, 2017 08:47 PM
92hatchguy
May 27, 2009 08:07 PM
skaterdude04
Honda Civic (2001 - 2005)
11
Feb 24, 2009 07:12 AM
Headlessmunky
Oct 24, 2008 08:41 PM
relic_sypher
Feb 7, 2002 06:46 PM
