B18c1 swap with code 23 (knock sensor)
Old Aug 17, 2012 | 09:45 AM
Mike Lawhun's Avatar
Default B18c1 swap with code 23 (knock sensor)
4 months ago did a motor swap from d16z6 Sohc vtec to b18c1 swap. Kept the original harness in the car but just used the motor harness on the b18. I get a check engine light once the car gets to optimum temp. I can shut the car off and start it immediately and the light is off until I drive maybe a 1/4 miles at optimum temp. Ive replaced the iac sensor as the code says iac sensor but doesn't cha.ge anything. BUT when I first did the swap I kept my p28 ecu connected til I could buy the correct one for the motor. When this light came.on is when I bought a p72 and connected is when I get this light all the time. I've tried disconnecting battery and everything it.will not go away. Any suggestions?
Old Aug 17, 2012 | 09:50 AM
jbpnoman's Avatar
Default Re: code 24 check engine light i cant get rid of
There is no code 24. Can you post a video of the flashes?
Old Aug 17, 2012 | 11:29 AM
2 long blinks followed by 4 short.
Old Aug 17, 2012 | 12:04 PM
JNocon's Avatar
Do you have a code reader on hand? Man, that thing is really helpful when you have a CEL on. If you don't, you should invest in one. It's not that expensive.
Old Aug 17, 2012 | 12:40 PM
d15bvtechatch's Avatar
this may have to do with one of your coolant sensors... ECT..THERM fan.. i had this same problem a few months ago in my b16 coupe and it was the ECT sensor. cheap fix
Old Aug 17, 2012 | 12:48 PM
HondaPartsHero's Avatar
Technical Hero
Sounds like he has OBD1 which doesn't use the code reader hookup. Post a video of the blinks. My guess is that its code 10 and 14
Old Aug 17, 2012 | 12:50 PM
im stupid
Old Aug 24, 2012 | 03:27 PM
Sorry I haven't reposted, I'll do the code thing tonight. But yeah I have obd1, and also @ d15 hatch with this problem did it make your car burn more fuel as well with this light on? I understand type r tranny shorter gears and stuff but my god I don't ever get on this thing I drive like a granny actually.to save gas but 200 miles on a full tank?!?!?!?!
Old Aug 24, 2012 | 05:14 PM
Former User's Avatar
Old Aug 26, 2012 | 01:45 PM
how do you upload videos on this thing?
Old Aug 26, 2012 | 01:46 PM
Upload video to a site like YouTube and then post the link.
Old Aug 26, 2012 | 02:08 PM
http://youtu.be/3WQQ9uC8XCk
Old Aug 26, 2012 | 02:14 PM
Code 23 for knock sensor
Old Aug 26, 2012 | 02:16 PM
where is that located on a 94 GSR?
Old Aug 26, 2012 | 02:17 PM
Back of block
1-wire sensor
Old Aug 26, 2012 | 03:05 PM
Default Re: B18c1 swap with code 23 (knock sensor)
ok appreciate it... Any reason to why with the p28 ecu didnt give a code until i switched to the p72?
Old Aug 26, 2012 | 04:12 PM
Technical Hero
The p28 doesn't look for a knock sensor
Old Aug 26, 2012 | 07:26 PM
oh, hmm makes me wonder if this thing is even bad. Ill try replacing it next weekend but thanks for your help.
Old Aug 27, 2012 | 01:27 AM
Technical Hero
Is it even connected and ran to the ecu?
Old Aug 27, 2012 | 05:19 AM
typemismatch's Avatar
Honda owns me
The stock harness won't have a provision for a knock sensor, you would have had to run the wire to the ecu. If you didn't run the wire, there's your problem.
EGk3nrock
Apr 27, 2007 06:59 AM
ludedude808
Aug 23, 2006 09:42 AM
Eg6_LsR
Oct 14, 2005 06:27 PM
95DXPhiladeph
14
Jun 7, 2004 05:46 PM
Nos4R2
Feb 18, 2002 03:48 PM
