f20b swap into 99 civic ex question?
I am doing an f20b swap into my 99 civic ex and am wondering can I keep my Air conditioning, like use the compressor that's attached to the f20 block? I have no clue if it will clear or fit at all. I am also wondering would it be smart to take my b-series engine harness and extend it to make it work for the f20b or just get a rywire harness made for my specific application even though its a bit expensive? any help would be great guys.
Re: f20b swap into 99 civic ex question?
if you are doing h2b then no ac... or you would have to make room up front+custom ac lines... as far as the harness, if you have the f20b harness you can use it to make a coupler to the f20b distributer. that is what i did. f20b F2b 99 si harness. I assume the ex is the same harness... maybe difference is the iacv connector. G/L
Well too bad u sold the car. U CAN KEEP THE AC innovative and swap shop have the bracket oh well. Too many "experts" giving false info here
I'm looking to put A/C in an F2B 99 EK swap.
