B swapped '00 Coupe Problem
Old May 29, 2012 | 09:29 AM
McMahon's Avatar
Default B swapped '00 Coupe Problem
Its been running fine for weeks, but the other day I was low on gas and when I went to start the car, it had a hard time starting. Once it started, when I hit the gas, the RPM's would drop and the car would almost die out.
So I figured I was just low on gas, so I filled her up.
Its still doing it, but only on a cold start.
Any ideas?
Its a B18B with AEM FPR, jumped to OBD1.
Old May 29, 2012 | 11:31 AM
gzes's Avatar
Default Re: B swapped '00 Coupe Problem
Have u checked ur fuel filter. If it has no gas it caja oick up junk and clog the filter just enough to not let it get in enough gas
Old May 29, 2012 | 12:01 PM
Robin6's Avatar
Clean your IACV
gsxremep3
Aug 29, 2013 08:30 PM
Jdm_risings0n
Oct 8, 2009 06:24 PM
shadohconspiracy
34
Apr 12, 2008 03:29 PM
wolverinept
May 16, 2007 06:25 PM
igo4bmx
May 20, 2005 12:58 PM
