Mount Question
Old Jul 18, 2012 | 05:34 PM
Slacker93eg's Avatar
10 Year Member
Default Mount Question
It appears I have the wrong motor mounts. I'm swapping a b18b1 into my 93 civic hatch.
The bracket on my block that I picked up has 3 holes, but only 2 studs are in there (so I assumed you could use a 2 bolt style?) Apparently it won't work, the bolts are too close together for the mount. Should I return the kit or just buy a 2 bolt bracket and replace that? And if I should just get a new bracket, who has one for sale?
I guess I should just ask if the EGSTK will fit in my car if I replace that one bracket to a 2 bolt left? Or will the other two mounts not fit either? Somebody please help so I know if I had to return these or not
Thanks in advance.
Old Jul 18, 2012 | 05:52 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Mount Question
return the kit for the proper one is my opinion
Old Jul 18, 2012 | 05:54 PM
10 Year Member
Well then which kit is the proper kit? I think the bracket I bought is just the wrong bracket, but Idk if the other mounts will fit? I'm pretty confused... EGSTK or ?
Old Jul 18, 2012 | 06:08 PM
10 Year Member
My gut feeling is that if I were to just replace the left mount to a 2 bolt I would be fine, I don't want to have to pay shipping and restocking fee's if I don't have to
Old Jul 18, 2012 | 06:29 PM
MEn'MYEK's Avatar
I wanna say the 2 bolt side mount is for an ek. 3 bolt for eg
But I could be wrong
Old Jul 18, 2012 | 06:48 PM
10 Year Member
All the research I've been doing says that b18c has a 3 bolt, b16/b18(a/b) use 2 bolt. Apparently I got the b18c bracket and I need a b16/b18 bracket. And they are interchangeable, I was just worried the other two mounts wouldn't fit, but they should be the same?
Old Jul 18, 2012 | 08:00 PM
Nickeg9Ej1's Avatar
they are the same only thing that changes in the driver side mount depending on which bracket you have.
Old Jul 19, 2012 | 05:54 AM
YZFR6's Avatar
If you have the B18b1 with the 3 hole driver mount you'll want to use any aftermarket for a DC2 Integra or use 94-01 Integra mounts. Hope that helps
Sille98
Jul 24, 2015 07:41 AM
gottabfast
Feb 18, 2009 04:35 PM
tree fingers
Aug 15, 2008 11:36 AM
fin781
Feb 28, 2008 05:38 PM
JDM CTR EK
10
Jun 16, 2004 04:02 PM
