B18B1 into a 97 Civic HX Transmission issues
I'm having issues with the transmission wiring (Automatic), it doesn't seem to start in first gear and it doesn't accelerate like it should. In reverse, it goes smoothly, but in drive it revs high and doesn't take off like it should. Everything else in the car has been wired properly to my knowledge, all the electronics and dash work, and the lights, i just dont know whats going on with the transmission. Is it beacuse the HX used to have a CVT? Do i need to change the shifter all together? I just had an oil and transmission fluid flush, so that isn't the problem. Help anyone? I've looked through the FAQ and havent really seen anything to fit what i need, any help is appreciated.
Re: B18B1 into a 97 Civic HX Transmission issues
Bump, also checked the wiring with http://www.ff-squad.com/technet/wiri...schematics.gif and found out that:
-the 2nd injector has a red wire instead of blue
-i need to do the IACV switch (A12-14) and the Code 91 fix(D15)
-the alternator control wire(A19) is green and yellow instead of green and white
-the reference volt. is white and red instead of white and black (A25)
-C29 is light blue instead of light green, which could be what i need since i have transmission problems.
-I'm missing A28-29, D15, C23-24
silver-EK
01-24-2006 09:15 PM
