98 civic with lsv, spark, fuel, compression, and timing correct but no start
so ive posted a few times throught the thread about my car, recently the car had started breaking up bad and wouldnt go over 3k, my cel through a good amount of codes and pretty much didnt wanna run well at all, so i took the entire harness out and found a good amount of wires that had become un spliced and were just a mess. i had re connected the wires and heat shrunk them all, i then put the harness back in the car the same way i had takin it out and the car wont start, i checked for spark its all good, the fuel pump is priming and the fuel pressure guage is reading 40psi, i checked compression and its 125psi across, i checked cam timing and its all on point, i sprayed starter fluid and still nothing, i checked all relays, fuses and grounds. on top of it all my starter literally snapped off the mounts and fell out so i need to get a new one tomorrow, ive been trying to figure this for the past few days with no luck at all i dont know what more to do at this point
Re: 98 civic with lsv, spark, fuel, compression, and timing correct but no start
Hey I have heard of this happing.. Actually it happen to me..lol on my b20b gsr swap did you ever figure out what the problem was..
New starter now installed?
CEL codes?
Plug wires connected in correct firing order on distributor cap?
Sensor connectors match sensors?
Is spark BRIGHT WHITE at all 4 spark plugs?
Original thread closed as only one thread is allowed per topic.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/98-civic-lsv-swap-misfire-above-3k-rpm-cel-code-8-a-3071163/
CEL codes?
New starter is now installed. I originally had codes 6,7,9,17, and 21. Now I only have 6 and 21. The spark is white throughout all 4 and the firing order is correct, I triple checked all connectors to make sure they are all correct.
FIX code 6. Does the engine start if you unplug the ECT sensor? Do you know where it is located?
Post sensor connector pictures with wire colors -- or at least list wire colors in the connectors. Provide information that is verifiable. Same for plug wire order.
im not to goood with wiring but i put everything back as it was before i took it out, there is only one issue and that is there are a few connectors with no were to go. the car was automatic so could it be that they are from that ? i will post pics of all connectors/wire colors. when i got the car it had all the original codes and ran fine, thts why i dont understand why it wont run now out of know were.
Regardless, having all those CEL codes was extremely bad. Those codes raised a huge red flag about the poor quality of the swap and most surely affected the car's performance.
At this point, it would be a huge mistake to assume anything is fine. This could cause you to miss something important. By providing the necessary information, you allow us to verify it.
ok, i will get out there now to take as many pics as possible to give every one a better point of view on what im dealing with
Yeah im having the same problem I have a 93 hatch b20b vtec swap. I put lowering springs and tried to start and the starter broke off now with new starter installed car wont start just spinning and timing is tdc all the way so if you figure out what it is please share and let me know
Wow what a mess. I would get a hole new harness for a 96-98 Ex or a 99-00 Si. A 96-98 DX or LX harness will work but you need to add Vtec and a knock sensor if you are running one. If not for any than piece of mind and a cleaner bay. Also keep in mind that having a messed up harness can can fry the ECU if wires get crossed or miss wired.
What is the origin of the engine wire harness?
What ECU?
The picture for the spark plug wires also needs to show the cylinders that they run to.
What ECU?
Is your timming dead on tdc? And your mass air flow sensor wasnt plugged in kinda looks like plugs arent right either post diffrrent pics of top
The harness is a Hack job as stated, it's the stock 98 ex automatic harness with a step down to a p72. I work at a Honda/Acura junkyard so getting a new harness isn't an issue. Which harness should I grab ? There is some one local that has a b series ready harness. I will take pic of spark plug wires
Pictures in order, top to bottom:
#1 - CKF sensor connector
#2 - power steering pressure sensor connector
#3 - knock sensor, right headlight, or cruise control?
#4 - not sure what we're looking at
#5 - IAT sensor (match) and MAP sensor (hacked but match)
#6 - IACV (match)
#7 - TPS (doesn't look like TPS to me)
#8 - not sure what we're looking at
#9 - injector power = all Yel/Blk; grounds ---> #1 = Brn; #2 = Red; #3 = Blu; #4 = Yel (These look out of order)
#10 - need better pic of plug wires
Picture of the ECT sensor is missing.
#6 - IACV (match)
#4 i was taking a pic of the green plug on the block, and i was wondering which of the first 3 pics goes to it, also next to it theres a male conector popping out that has a female connected to it thats a yellow wire
Please address my comments to #7 and #9.
1-3 are loose connectors that idk where they go to, pic 4 is what im assuming one of the plugs goes to, not the alternator green connector the one thats on the block next to the oil pressure sensor. as for pic 7 thats the only plug close enough to plug in there. its a 3 prong opening but one is blocked off so the two off the tps itself fit rite in, that sensor was there ziptied on before i took it off, unless theres a diff connector that goes there. also an update. i just took my injectors out and turned my car to accesory and no fuel came out, i tested all the clips and there all getting power.
I now see the green area where a plug would go. How many terminals does it have? What engine and year does your block come from?
I've asked this several times without a response ---> Where is your ECT sensor and what color wires does the connector have?
