Need help on Obd Conversion!
Old Jun 12, 2012 | 11:04 PM
legend01234's Avatar
Icon3 Need help on Obd Conversion!
i swapped a D16z6 into my 96 Honda civic Ex, because the D16y8 blew up. Everything is in and now i need to change the OBD but am having a hard time could someone explain what wires go to what other wires like color to what color and input would really help. Oh and i dont know if this is in the right area.
Old Jun 13, 2012 | 02:38 AM
rd91sib18c5r's Avatar
Default Re: Need help on Obd Conversion!
If you use your original manifold dizzy and injectors you can keep it obd2.
Old Jun 13, 2012 | 02:39 AM
rice a roni's Avatar
all ur wires should hook up except the crankshaft sensor and knock sensor, they dont need to be hooked up. u will need and obd2a or b to obd1 harness depending on model year and a p28 ecu from a 92-95 civic ex.
Posted from Honda-Tech Forums Reader for Android
Old Jun 13, 2012 | 02:42 AM
word, keep the manifold, alternator and dizzy.
if he wants to stay obd2 he needs to thread in the knock sensor and bypass the cks.
Old Jun 13, 2012 | 08:49 AM
The dizzy doesnt mount up right, just the top bolt does. is there anyway to fix that?
Old Jun 13, 2012 | 10:13 PM
If you can get the timing right,cut off part of the other tabs to get a bolt in.
I have ran 1 bolt when I had a ls with a d16 dizzy just leaked a little oil.
EK8D15B
Sep 8, 2007 05:39 PM
eh2
May 6, 2007 07:25 AM
egb16pg
Mar 1, 2007 11:39 AM
sohcracer
Mar 16, 2003 04:28 AM
ITR21
Jul 25, 2002 02:39 AM
