HELP, B18B in EJ8 throwing 5 codes
Old Aug 8, 2012 | 10:21 AM
JdmCoupe91's Avatar
Default HELP, B18B in EJ8 throwing 5 codes
So I had this swap running in my ej6 with codes for o2 sensors and CKF. Ran the car like that for a year and it ran OK. Pulled the swap out, had it sitting for about 2 weeks, did plugs, wires, vc gasket, and put the swap into my ej8. Bolted the exhaust up and now it's throwing the previous codes, plus P0108(MAP) and P0113(IAT), and every time i open the throttle it wants to cut off. So my question is: would I be able to get away with a step down harness (obd2a to obd1) and p28 ?
I just need a yes or no, or what would be causing this. Thanks in advance.
Old Aug 8, 2012 | 08:15 PM
tunerboy254's Avatar
Default Re: HELP, B18B in EJ8 throwing 5 codes
sounds like you might have the plugs crossed
Old Aug 10, 2012 | 07:44 PM
JdmCoupe91's Avatar
^Fixed. You were right. Rookie mistake ._.
Still gonna run the step down harness for that crank code though. I hear they run better that way. Thanks.
slammedvtec
Mar 26, 2008 05:12 PM
b18egdx
Aug 8, 2006 05:19 PM
slammed_coupe
Jan 9, 2006 10:05 PM
D16Z6_turbo
Feb 9, 2005 05:41 AM
89 JDM CRX
Apr 1, 2004 11:44 AM
