b18a1 swap into 95 civic ex
I HAVE SEARCHED EVERY WHERE SINCE LAST NIGHT. i cannot find and exact answer to what i need, i need to know exactly everything i need for the swap, and how to wire everything. i also want to use a cable tranny, my car is an auto chassis, so either way i have to convert. HELP please!!
95 civic ex ej1 auto chassis
Re: b18a1 swap into 95 civic ex
b18a1 exactly. ive found everything for b18b and a few others, but not the a1 specifically, i know im probably going to get flamed for this, but i cant seem to find anything.
Technical Hero
Um sorta but not. The B18A1 came in OBD0 and OBD1 varieties. What year is your B18A? BTW don't use the cable tranny it'll never work right, I know you're trying to be cheap but it's not worth it in that case. Find a 94-01 hydro LS trans.
i live in ms, and its already hard to find an unwanted cable tranny, much less a hydro tranny, if im not mistaken mine is from a 91 teg.
btw, thanks, finally someone sees my epidemic. i knew that somehwere they had minor differences. thats part of the confusion. lol
In short B18A1 motor and trans (hydro not cable) if you can find a 94-01 GSR trans or a 99-00 Si trans.
OBD1 Ls ECU and harness
Turn key and drive, pretty sure there is no repining needed at the ECU plug on this swap but please correct me if I am wrong.
Technical Hero
Um yeah he obviously isn't going to ditch the cable trans so I'll doubt he will ditch the motor
The 91 B18A is OBD0 so he can't use the injectors, distributor, ECU, 02 sensor, or wiring harness. You can reuse your ex injectors which is fine. You'll need 92-95 LS ECU and distributor. You can reuse your wiring harness. The B18A doesn't have a TB mounted MAP do you can use your ex TB or use a OBD1/2 bseries TB. The fan switch is on the back of the block so you'll have to run the wiring to back there instead of the thermostat housing of the ex engine. He has an EG so 99-00 mounts won't work you'll want 94up Integra metal mounts and reuse your civic rubber portions.
You still need the 99-00 Si rear mount bracket since the D series is different and so is the Teg and you will need the 99-00 Si upper left mount bracket the one by the timing belt since the one on the B18 will not line up correctly with the Civic chassis or the Civic mount.
If this is a OBD0 motor you are doing tons of unneeded work to make it work. Get a OBD1 motor and start there, sell the OBD0 motor.
Kronoc
02-06-2014 04:04 AM
