1996 b18c in 1996 hatch. what is this hole for? pic inside.
imagine your in the drivers seat looking foward. the hole is directly below the valve cover on the left side. http://postimage.org/image/el9pd5ce3/
also, what do I do with the #12 hose in the diagram http://img386.imageshack.us/img386/2...diagramoa7.gif
I don't have a evap solenoid. I don't need to pass emissions. what can I do with this hose?
Location: Pensacola, FL and every Court House in Louisiana
Re: 1996 b18c in 1996 hatch. what is this hole for? pic inside.
That is to attach a I-bolt when pulling the motor so you strap your strap to. At least that is what I have always used it for.
The evap can is used to allow the fuel tank to breath without the fumes getting out. You can just plug the tube if not using. Personally I would get a evap can to keep the gas fumes under control .
RESIDENT
arielb1
01-13-2018 12:32 PM
