LS/VTEC problem
Old Jul 14, 2012 | 04:21 AM
TeranceFL's Avatar
Default LS/VTEC problem
just trying to get this solved before I spend money on a good tune.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/ls-vtec-problem-3066906/
"ok so i had my lsv build for about a few months already and it just recently got rebuilt so its running like 1k on the engine. Anyways im running a b16 head with b16 tranny on a LS block of course and a od1 p72 chipped with vtec @ 4.7k There is times I feel the full potential in my engine and others when the acceleration just feels sluggish. Today I was hitting it and i heard a change over around the 6.5k mark and my car hit it but other times it just doesn't kick. Can this be in my head or ecu problems, exhaust leak, vtec dying than coming back?"
"so I realized when I'm running cold after letting my car sit for awhile it pulls but after driving for about 10mins, warms up and its back to sluggish feel. It cant even reach 8.2k when on warm. Is this still from not being tuned or bad chip or most latest suggestion my intake being heat soaked."
Old Jul 14, 2012 | 04:52 AM
GOOZILLAAA's Avatar
Default Re: LS/VTEC problem
I think your vtec is set too low!!! try 6000 it may help a lot, it helped me. but yeah get it turned before you mess something up.. the tunner can help set it for you
Old Jul 15, 2012 | 12:15 PM
TeranceFL's Avatar
Should something go where that green sensor is?
Old Jul 15, 2012 | 12:58 PM
JuggerNaut-CTR's Avatar
Um yeah....thats the vtec pressure switch...fix it
Old Jul 15, 2012 | 02:48 PM
Lou845's Avatar
unless they have the wire from the solenoid itself ran to another power source causing a crossover ?
Old Jul 16, 2012 | 10:36 AM
cvcrcr99's Avatar
If you need a new plug and if you know that a H22 sensor will work, I have one for ya. Shoot me a PM.
Old Jul 18, 2012 | 03:04 PM
elmanre's Avatar
It depends, on LS vtecs you dont need oil pressure switch if the ECU is chipped and tuned, but if you are using the ECU stock, you need to run the oil pressure switch, that is going to cause vtec not to work...
TeranceFL
11
Jul 15, 2012 02:50 PM
iBear
Aug 17, 2006 08:02 AM
dohcivicls
Jul 29, 2005 02:21 PM
Boostless97Lude
Jun 6, 2002 08:18 AM
teg92
Nov 22, 2001 12:12 AM
