wiring with a B20b swap into a 98 civic ex 2dr
Old 07-18-2012, 08:33 PM
Serge L's Avatar
Default wiring with a B20b swap into a 98 civic ex 2dr
im getting ready to start buying everything for this swap still waiting for a few more dollars, but i know i need
b16 motor mounts
ls tranny with mount
b series shift linkage
b series axles
ls or b16 ecu??
im confused about the engine harness????
what kind of harness would i need? ive been reading around and getting mixed answers
this is what ill be getting
http://zerolift.com/products/honda/b...-intake-engine
Old 07-18-2012, 11:51 PM
Jdmglenn's Avatar
Default Re: wiring with a B20b swap into a 98 civic ex 2dr
99-00 si timing belt block mount, the ls tranny will work, use stock ek top tranny mount, rear 99-00 si T-mount, and an ls ecu. You will use your stock engine harness minus the vtec plugs and the knock sensor plug will no longer be used.
Old 07-19-2012, 08:51 PM
Serge L's Avatar
so my d16 tranny mount will work on the Ls? as well as my d16 harness? with A/C i would just need to get new lines right, and i read that the power steering pump is compatable with the b20 that true
thanks for not being a dick to me about "not researching"
cant wait to get this going.
Old 07-19-2012, 10:04 PM
Jdmglenn's Avatar
the top one yes, your harness yes, a/c i think you can use p30 delsol one ( i may be wrong)
Old 07-19-2012, 10:37 PM
Serge L's Avatar
alright thanks man!
ej8_fredi
09-17-2008 05:44 PM
biggjerryc
09-13-2008 10:48 PM
civic-skeeter
05-01-2008 10:26 AM
phatboi
01-07-2005 03:21 AM
kingdan9034
09-01-2003 07:29 PM
Quick Reply: wiring with a B20b swap into a 98 civic ex 2dr
