Quick iacv question.
Old Jun 5, 2012 | 01:38 PM
sibleywibbley's Avatar
Default Quick iacv question.
Iacv, correct?
I thought wires were supposed to be green/black, and black?
Not blue/yellow, Yellow/black.
Or is that just b series vtec?
What wires would I run to the 3 wire iacv? (I know orange'll be a dead wire.)
Edit: oh, it's a b18a1 head.
It's going in the ek chassis, with the stock CX harness.
Old Jun 6, 2012 | 07:16 AM
Default Re: Quick iacv question.
I talked to the guy I got it from, the engine harness is off a z6.
Old Jun 6, 2012 | 07:28 PM
Bump for some help maybe?
Old Jun 7, 2012 | 01:14 AM
HondaPartsHero's Avatar
Technical Hero
Those wires are correct
http://civic-eg.com/viewtopic.php?t=12066
The wire colors you are thinking of are for a 3 wire IACV. The Z6 harness won't work in your EK. You'll have to use your CX harness and do the necessary 3 wire IACV conversion plus a good number of other wiring modifications.
Old Jun 7, 2012 | 06:06 AM
Thanks. I'll use that.
But which wires do I run for the iacv fix? The only diagrams I can find are for the ls harness, but ls swap with z6 harness?
Normally the yellow/black would be to green/black, and black/blue to black. Orange is dead, then run the ecu pinout. So would this basically be a z6swap? I'll help myself too, and look for a z6 to ek, or mini me swap wireing.
I'm using my information from here:
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
Old Jun 7, 2012 | 12:52 PM
Technical Hero
You can't use either the z6 or LS harness you have to use yours. What year is your car?
Old Jun 7, 2012 | 08:08 PM
Oh, I know that.
edit: the harness is so I can use all the plugs and sensors i need.
I have to re-wire in the obd1 iacv plug into my obd2a EWH.
I just don't know which wires to splice to which.
In this pic, the wires are a different color, so I was stumped.
(it's a 96 CX hatch btw)
Old Jun 8, 2012 | 01:11 AM
Technical Hero
Oh ok
Disregard orange
Blue/yellow - yellow/black
Yellow/black - Black/blue
That connector they show on the diagram is not a two wire IACV plug (the wires should be the colors you have) but the plug is the same style connector
Old Jun 8, 2012 | 05:27 AM
Awesome! Big help, thanks. Can't wait till my day off to get some stuff done!
spoolinvtec54
Engine Management and Tuning
11
Feb 13, 2020 09:45 AM
prodjay10
Mar 21, 2017 07:21 AM
cubanSiR
Sep 15, 2010 04:36 AM
bobobob
Nov 20, 2009 12:55 AM
RTW DC2R
Dec 31, 2004 04:58 PM
