d series questions ,help me with my swap!!!!!
Old 11-11-2002, 06:48 PM
theclutchpoppa's Avatar
Default d series questions ,help me with my swap!!!!!
alright guys here goes all the info,i have an 88 crx si with 88 ecu and tranny.Ijust bought a 91 d16a6 block with a z6 head on it.the 91 intake manifold is a little different than my 88 ,the 91 seems to have less vacuum lines and also has an extra plug on the back of the manifold.Can i use the 91 manifold or will i have to swap in the 88 manifold?is either one better than the other?and also what would be the best way to wire up the vtec?get a z6 ecu?rpm activated switch and fpr?thanks for all the help guys
Old 11-11-2002, 09:10 PM
the DR.'s Avatar
Default Re: d series questions ,help me with my swap!!!!! (theclutchpoppa)
i didnt know the 88 and 91 manifolds were different..
but the most ideal way to wire up is to convert to OBD I so you could run the proper ecu, and have the proper vtec fuel maps, but you can use a rpm switch if you want (this way you wont have to convert anything)
JdmRex25
20
07-07-2009 11:55 PM
jpnucrx
03-23-2005 07:29 PM
dumbchild
01-22-2003 10:55 AM
Agent Daimon
02-22-2002 10:30 AM
Quick Reply: d series questions ,help me with my swap!!!!!
