B20/vtec help
Old Nov 13, 2002 | 01:01 PM
93dx--hatch's Avatar
Default B20/vtec help
A friend and I are currently in the process of building a B20vtec, B20 bottom end with a 95 Gsr head, with a skunk2 intake man. it is going into an 89SI hatch
My question: what ecu to go with? the 1st gen B16?
What distributer to use?
Is any vtec pressure switch and solenoid going to work??
BTW: IF anyone has any of the parts I need for sale let me know.
Old Nov 13, 2002 | 01:21 PM
Kamin's Avatar
Default Re: B20/vtec help (93dx--hatch)
1) yes that will work, but id use hondata or at LEAST convert to obdI and a VAFC and have it tuned.
2) depends on your ecu. obdo or obd1
3) yes they are all the same.
Old Nov 13, 2002 | 02:19 PM
Default Re: B20/vtec help (KAMiN)
lets say obd0 what distributer then? What cars come with vtec OBD0?
Old Nov 13, 2002 | 07:35 PM
tinkerbell's Avatar
JDM?
t..
Old Nov 14, 2002 | 05:02 AM
Jeff C's Avatar
It doesnt have to be a vtec dist. If its obd0, you can use a 90-91 ls dist, but you have cut off the mounting point that interferes with the vtec solenoid. I am using an ls dist on my crvtec...works great.
If you use a 1g b16 ecu, then you'll need to run the necessary extra wires to satisfiy the ecu, ie. another o2 sensor wire. I am not familiar with that ecu though. I am using a chipped p28 ecu, but you would have to covert to obd1.
[Modified by Jeff C, 9:07 AM 11/14/2002]
efKART
Jan 4, 2007 10:28 AM
Itzmy91Teg
Jun 10, 2006 12:15 PM
JDMIntegR1
Aug 22, 2004 06:34 AM
showtymers619
Apr 14, 2004 11:00 PM
hoggy
Mar 31, 2004 10:29 AM
