what would you do with $12k.....
well me and a couple buddies are planning on building a semi-full-race EG hatch. we havent decided what motor/turbo/internals/etc where gunna get yet, but what would you guys get. sorry for the stupid question but im still learning a lot about honda's and i jes wanna know whats all out there. and how much **** is. TIA
EDIT: o and we still gotta buy the hatch with the 12k so put that in your expenses. thnx
[Modified by mitsuman, 5:36 PM 11/11/2002]
Unceasing Measure
Re: what would you do with $12k..... (couter)
Dart iron block with forged JE and Eagle internals with a hybrid turbo boosting 2.5bar, open header, drag suspension up front, gutted to hell with drag slicks.
PWN3D
PWN3D
Re: what would you do with $12k..... (mitsuman)
EG + internally stock B16 and a Greddy turbo.... hehe j/k that is one of the stupidest ideas i've ever come up with..... My friend Kenny has a GSR with Golden Eagle sleeves, JE pistons, Crower rods, Portflow B16 head, Rev Hard stage 2C turbo with a straight T04 turbo, a 42.5mm turbo inovation wastegate, JG Edelbrock Victor X intake manifold, 900cc injectors, controlled by a Blitz SBC boost controller and Hondata 4b. It's in his EK boosting 22psi which made 505whp and 350 torque. I would put this setup in an EG and let it go... hehehehe
My b20/vtec long block is for sale. Perfect if you want to go fast in your hatch. 200whp and 130-140wtq on motors with similar mods. Do you plan to go FI or NA? I live 15 minutes away from garden grove also, you can check out my motor anytime.
[Modified by Maximus, 10:43 AM 11/12/2002]
New User
Re: what would you do with $12k..... (n1ek)
Yes. What type of racing? that has a HUGE determination on how you build up the car. I cant even begin to describe anything without knowing what the goal was.
However.... In a nutshell. Road Race = high compression NA and head work. Drag Race = turbo and bottom end work.
Suspension setups are obviously completely diferent as well.
Mike
Mike
Re: what would you do with $12k..... (LoudAccord)
1988 CRX HF with B18c1, skunk2 stage 2 cams, eagle rods, jpe 9 to 1 compression pistons, Mugen N1 ECU, STR intake manifold, 70MM throtle body, REVHARD 2c turbo kit, blitz bov, some underdrive pully's and cam gears... relocate the battery to the hatch in order to make enough room for the turbo, upgrade axles with race axles, pop on some nitto's or hoosiers and pump about 15-20 PSI through there and your golden...you should be making in the 400HP range, but with a car that stock weighed 1800 pounds, that will be low 11's or 10's
Re: what would you do with $12k..... (Maximus)
PACKAGE 3: CRATED MOTORS 0003
<< Back Next >>
Description: "The All Motor KILLER" Package. 2 Liters.
**SMSP Header included in price.
**Portflow Designs Head Package, designed by Import Builders, only available to public through Import Builders. (This head package is not available through Portflow, only IB)
Includes:
new axles
shift linkage
ECU
wire harness
stock mounts
complete motor
Tranny included (B16A or GSR)
This is a KILLER total rebuild package for those of you that just want to be super fast. This package includes Import Builders completely revamping the motor. Sleeved block. Tranny with Honda LSD. New IB Spec forged pistons 84.5MM, new Probe rods, knifed crank, balanced crank, new bearings, new oil pump, bigger injectors, new fuel rail, new water pump, new timing belt, new alternator belt, new IB Spec valvetrain, new race cams, cam gears, Mugen chipped ECU 9500 RPM rev limit OBD1, new Clutchmasters light flywheel, fuel regulator, gauge, Hondata Stage 2NN, Injen Intake, "Special" intake manifold, Import Builders custom head package, 68MM TB, new valve seals, new head gasket, new valve cover gasket, and new CM Stage 4 clutch with new bearing. VTEC tranny with LSD, shipping included. When you get this motor package, you will not need anything. It comes with new oil, new filter, and the new radiator hoses with clamps. Just install it, break it in, and tune it.
Options:
Turbo package: no custom header, no intake, no big cams. IB "Killer" Turbo kit Add $2500.
Individual Throttle Bodies: add $1200.
Tuning options: Have us install, break in the motor and tune it, here!! Then we ship, you install, and that's it. Go race! $1500. Comes with Hondata tuning, of course.
Estimates: 220-250 HP at the wheels. (We have seen as high as 246, same build)
Price: est. $12,000 shipped Depending on car and HP desired.
Dyno Plots:
All Motor
Turbo 16psi | 17 psi
close window
That is where that money would go. IMO http://www.importbuilders.com
[Modified by SILINITY16, 3:34 PM 11/18/2002]
<< Back Next >>
Includes:
new axles
shift linkage
ECU
wire harness
stock mounts
complete motor
Options:
Dyno Plots:
All Motor
close window
Re: what would you do with $12k..... (EVOCELICA)
i worked the **** out of my suspension and bought an ITR swap. if i had just spent the money on beer my car would be running right now
-Sean
-Sean
Re: what would you do with $12k..... (irunfromcops)
h22 G3 integra w/ jackson racing supercharger. all the basic i/h/e. carbon fiber hood, lighter seats, or anything else to make it not front heavy. that'll slurp up that 12k i believe.
New User
Re: what would you do with $12k..... (smallttocs)
2500 hatch
3000 max rev kit with hondata
100 walbro
300 75lb/hr injectors
800 quaife
4000 gsr swap
400 tuning
700 slicks/wheels
400 clutch
500 JE's
350 Eagle
200 Machine work
13250..exceeded my limit...
100 walbro
800 quaife
4000 gsr swap
400 tuning
700 slicks/wheels
400 clutch
500 JE's
350 Eagle
200 Machine work
Re: what would you do with $12k..... (IntegD)
2500 hatch
100 walbro
800 quaife
4000 gsr swap
400 tuning
700 slicks/wheels
400 clutch
500 JE's
350 Eagle
200 Machine work
100 walbro
800 quaife
4000 gsr swap
400 tuning
700 slicks/wheels
400 clutch
500 JE's
350 Eagle
200 Machine work
