Help...dumb question about swap...
Old Nov 15, 2002 | 12:33 AM
SjCiViCHB's Avatar
Default Help...dumb question about swap...
allright dont get mad and flame me, ive done the research and use the search button and ive still haven't found the answer for my question. Its either i just can't find it, or im just too slow to see the answer.
okay, here's my question. Im doing a OBDI GSR swap in my 93 Civic DX. I have the complete engine harness from the GSR. Well reading all the info on how to perform the swap, i have to add a few wires to the harness, but it really didnt state that i had to add the extra wires if i had the GSR harness or the original harness. Well basiclly, if im using the GSR harness, and the GSR ecu, would i still have to add the extra wires? i hope thats clear enough, its hard for me to write what im trying to ask. Thanks in advance. *oh yea, virgin swapper so anymore info to add would be great!*
Old Nov 15, 2002 | 05:05 AM
jmm96gsr's Avatar
Default Re: Help...dumb question about swap... (SjCiViCHB)
yes you have add wires from the engine harness to the ecu. you have to add vtec, vtec oil pressure, iab, knock sensor. hope nobody flames you.
Old Nov 15, 2002 | 08:55 AM
poison's Avatar
Default Re: Help...dumb question about swap... (jmm96gsr)
VTEC oil pressure sensor needs ground which you can tap into Grn/Wht wire, and ECU Signal wire to the D6 pin-out on ECU
and
VTEC solenoid valve to A4 pin-out on ECU
Knock Sensor (mounted at rear of engine near cyl head) needs ECU Signal leading to D3 on ECU
and
IAB which one of the wires are to 12v source (correct me if wrong) and wire up to A17 at ECU
hope that helps
Old Nov 15, 2002 | 04:57 PM
Lysawy's Avatar
Default Re: Help...dumb question about swap... (poison)
http://tech.hybridgarage.com/tech/5g...html#ECUpinout
this might help
Old Nov 15, 2002 | 05:42 PM
youngkow's Avatar
Default Re: Help...dumb question about swap... (Cx Sir II)
You have to use the CX harness, and add wires to that. Unless your GSR harness has the plugs to the ecu on it too.
Old Nov 15, 2002 | 08:40 PM
SjCiViCHB's Avatar
Default Re: Help...dumb question about swap... (youngkow)
so if the GSR harness has the plugs to the ecu would i still have to add wires?
also another question to clear up for me...the wires that i have to add to the ecu, they're found on the harness right?
Old Nov 17, 2002 | 08:10 AM
jmm96gsr's Avatar
this guy has a dx not a cx. READ THE WHOLE POST!! use the gsr ENGINE HARNESS. plug that into the your civic harness that goes into the firewall. inside the car the civic harness will plug into the gsr ecu. now this is when you add wires coming from the engine to the ecu. your civic harness that goes through the firewall does not have the wires that need to be added. the gsr engine harness does have them. if u cant understand this then pay someone to do it for you.
Old Nov 18, 2002 | 12:12 AM
SjCiViCHB's Avatar
You have to use the CX harness, and add wires to that. Unless your GSR harness has the plugs to the ecu on it too.this guy has a dx not a cx. READ THE WHOLE POST!! use the gsr ENGINE HARNESS. plug that into the your civic harness that goes into the firewall. inside the car the civic harness will plug into the gsr ecu. now this is when you add wires coming from the engine to the ecu. your civic harness that goes through the firewall does not have the wires that need to be added. the gsr engine harness does have them. if u cant understand this then pay someone to do it for you.
allrighty! That clears alot of it up for me, thanks alot. Now i really understand. Thanks again man.
Old Nov 18, 2002 | 04:19 AM
jmm96gsr's Avatar
glad i could help.
augie1209
Honda Civic (2001 - 2005)
Jan 10, 2013 07:52 PM
omgwtfbbq
12
Apr 30, 2009 05:21 PM
dashskier540
13
Oct 24, 2006 11:54 AM
EG6-madness
Mar 21, 2004 08:09 PM
mrbsponge
12
Jan 25, 2004 08:08 AM
