b18a swap
Old Nov 10, 2002 | 04:24 AM
slow hatch's Avatar
Default b18a swap
Does anyone have a list of parts i need to have to put a B18a into my 88 hatch DX. Also have 90 integra for parts, what can i use off of it?
Thanks
Old Nov 12, 2002 | 11:15 PM
CRX-Hybrid's Avatar
Default Re: b18a swap (88' Honda Hatch)
I will try and help you and say that you would need both axles off of the 90 Integra, engine w/tranny, ecu, wiring harness is questionable of either stock crx or integra, motor mounts http://www.hasport.com but I have a set of new b series 4th gen mounts that im not using.... contact me if your interested....
Old Nov 13, 2002 | 01:27 PM
Cjsls's Avatar
mounts: Hasport M88-B16-10
ecu: PR4
axles: 90-93 teg w/ 90-93 teg intermediate shaft
shift linkage: shortened 90-93 or Hasport custom
upper/lower radiator hoses: 90 teg, trim to fit
throttle cable: 90 teg
clutch cable: stock
wiring: injector and distributor wiring needs to be modified
haha...i was bored
[Modified by cjsls, 7:28 PM 11/13/2002]
Old Nov 13, 2002 | 06:58 PM
Godspeed91's Avatar
Default Re: b18a swap (cjsls)
how should the distributor wiring be modified? I did a swap and get no spark?
[Modified by Godspeed91, 3:58 AM 11/14/2002]
yellowCRX6
Jan 24, 2004 08:49 PM
slow hatch
Nov 9, 2002 04:36 PM
89 CRX SI
Sep 16, 2002 07:52 PM
elpermgrande
Sep 11, 2002 07:44 PM
pfcfutrell
Aug 8, 2002 07:35 PM
