Header question...B18C GSR into EG, type r, ls?
Which header will fit a GSR motor in a 5th gen civic? My 4-1 B16A header is way off and I know none of the b16a headers will fit. Obviously a GSR header will fit, but I was wondering if maybe an LS or Type R header will save me from having to extend the cat and get an O2 bung welded in. Anyone using either on their swap?
Re: Header question...B18C GSR into EG, type r, ls? (CVC9216)
It doesn't matter which header you run, you're still going to need to extend the cat. Headers might differentiate in length a little, but not what you need. Any time you swap in a motor this is one consideration you must think about. If companies were smart they'd make extended headers to fit swapped cars. Hey wait, that's a great idea. Copywrite on that!!!
Re: Header question...B18C GSR into EG, type r, ls? (Specail Ed)
I would go with either an LS or ITR header because it's got the oxygen sensor port alread plumbed into it... Laterz
Re: Header question...B18C GSR into EG, type r, ls? (JDMspecEG6)
what sort of 5th gen civic is it? if its a hatch (eg) then here you go:
1) a type r header and cat will bolt straight up to the hatch exhaust-
2)gsr cat header/cat will be too short and will need an extension.
3)I believe (but am not absolutely 100% certain) thay a type r header and ls cat will work as well
good luck
good luck
