P30 or P28
Old Nov 17, 2002 | 11:10 AM
baonest1's Avatar
Default P30 or P28
i have an ls/vtec going in soon with hondata. on accident i was sent a p30 instead of a p28. now i wanna know if this would be just as good as the p28. i know the p30 has knock sensor and p28 doesnt. would i have any problems? i have a 95-96LS block and a '00 ITR head.
thanx
Old Nov 17, 2002 | 03:14 PM
eg6ajk's Avatar
Default Re: P30 or P28 (baonest)
USDM p30 allows for the knock sensor board to function without any downsides. once you get the hondata rom programed in you want, you'll have the option of turning the knock off or leaving it on.
Old Nov 17, 2002 | 03:46 PM
baonest1's Avatar
Default Re: P30 or P28 (eg6ajk)
its a JDMp30... can i still turn the knock option off. and if i do that then would it be just like a p28??
Old Nov 18, 2002 | 08:07 AM
baonest1's Avatar
Old Nov 18, 2002 | 08:52 AM
CHEETAH's Avatar
yes you can turn KS off ... I can reprogram those to shut off KS also ... and I can custom fit your timing and fuel maps and vtec x-over if needed, just PM me
greg
Old Nov 18, 2002 | 12:15 PM
baonest1's Avatar
Default Re: P30 or P28 (CHEETAH)
thanx.. its already programmed for the hondata. i was just making sure its the same as a p28.
Old Nov 19, 2002 | 12:00 PM
Kataku2K3's Avatar
The JDM P30 won't allow you to pull codes from the CEL.... But if there are no problems then who cares... Laterz
[Modified by JDMspecEG6, 1:01 PM 11/19/2002]
scuffywin
11
May 1, 2007 09:12 AM
hialeahzbg
Oct 13, 2005 05:15 PM
Arch-Angel
Apr 28, 2005 05:31 PM
Memo6453
May 26, 2004 11:11 AM
