Cat-Back after swap
Old Nov 15, 2002 | 08:49 PM
Stroker
Guest
Posts: n/a
Default Cat-Back after swap
I have a 98 civic h/b. With a b16, that has a Type-r head on it with a R 4-1 header, i never have had an exhaust on the car so i dont know what will work for an exhaust, i am runing no cats on it . So i am not sure if a regular aftermarket exhaust will work on it, without it having to be modified, any input would be great, thanks
Old Nov 16, 2002 | 07:06 AM
mitsuman's Avatar
Default Re: Cat-Back after swap (stroker)
no cats? you only have one. sounds like you have a moded exhaust allready. what do you have in place of the cat? a test pipe? if you got a cat back exhaust, the only modifying you would do is takin off the stock piping and muff and replacing it. hope that answers your question.
EDIT: well after reding your post again i guess your asking if a aftermarket exhaust would bolt right in. i believe it should. but not 100% sure. anybody?
[Modified by mitsuman, 1:08 PM 11/16/2002]
Old Nov 17, 2002 | 06:07 PM
Stroker
Guest
Posts: n/a
Default Re: Cat-Back after swap (mitsuman)
thanks well see on thursday when the apex n1 gets here
civic702
Aug 7, 2003 08:38 PM
Stroker
Nov 16, 2002 09:50 AM
Hype-R
Nov 13, 2002 07:53 AM
fOmaNPu
Jul 2, 2002 01:42 AM
98DC2
Jun 6, 2002 06:54 AM
