shoping list for my B18C1 swap into 88 CRX...
I have searched and come up with this list of parts I need to do the swap.
B18C1 engine already have
Tranny, trying to fix my ys1 lsd
axles, if I can fix the ys1 I have them.
OBD0 > OBD1 harness ordering from blown90hatch
P72 ECU still trying to find a good deal on one.
Mounts. probably going to get HCP with adjustable shift linkage.
please let me know if I missed anything.
Now what should I do to prep the engine, I belive the timing belt was just changed on the engine, it is a 97 with 100k miles, so I guess the water pump was also changed. I dont know how good the clutch is, so im thinking about getting a new clutch.
what else do you think I should do before I drop the engine in? or if anyone has any suggestions before I start the swap please let me know.
thanks
thanks
Re: shoping list for my B18C1 swap into 88 CRX... (DOHCarp)
https://honda-tech.com/zerothread?id=325414
Check it out.
If all the stuff on the motor you listed have been swapped, you should be ok. But DEFINITELY get a new clutch, and also plugs and wires too.
If you have any more questions just ask.
Check it out.
808EK4
16
01-21-2009 09:57 AM
