Converting OBD1 JDM GSR to OBD2...Reveiw my checklist please
Alright so after searching and reading my *** off I came to the following conclusion.
I'm going to run OBD2 in the car (ek) with the ODBI gsr motor...Is this everything I need to do it ?
I'm getting an OBD2 Distributor
96+ VTEC Oil Pump with the Crank sensor built in
Is there a diff in the alternator from OBD1->OBD2 (I've seen mixed info)
The fuel injectors are getting replaced with aftermarket units so not worrying about them.
I feel like I'm missing something.
Re: Converting OBD1 JDM GSR to OBD2...Reveiw my checklist please (Prod)
But you'll still need an OBD2 distributor, injectors, 2n 02, and 96+ B-series alternator. Yes, you'll need a 96+ B-series alternator...they use a smaller square green plug...previous models use a big round green plug.
I highly suggest going OBD1 as far as the ECU goes.....you wont have to spend $$ on an OBD2/bseries oil pump at all, nor worry about a 2nd 02 sensor.
Re: Converting OBD1 JDM GSR to OBD2...Reveiw my checklist please (Katman)
Katman, I considered converting to OBDI. As a matter of fact I'm still open to that. I am going to be running the AEM EMS so I guess it wouldn't matter I ran OBD1 or 2...I'd just have to buy the proper AEM. That's basically what's fueling my whole decision...tough one
Yeh, I'm just worried about getting into some super complicated mess with the EMS not being able to control a certain subsystem due to a different sensor etc etc
If I went OBD1 motor I'd have to buy the ODB1 EMS and a conversion harness so I can plug in the EK Harness to the OBD1 EMS. The lesser of two evils perhaps
hmm I duno about that..
I'd suspect if you bought an OBD1 ECU jumper and used an OBD1 EMS, it should work without problem. OBD2 and OBD1 engines are almost 95% exactly the same....only difference is that OBD2 engines have a couple extra bullshit sensors.... (CKP, 2nd 02,) ...that's it...
If I do that do I still need to get all of the below ? No right ?
"But you'll still need an OBD2 distributor, injectors, 2n 02, and 96+ B-series alternator. Yes, you'll need a 96+ B-series alternator..."
Deffinatly go OBD-I, you can buy the harness conversion for around $200 from kenji, well worth the $200, and you'll have less of a headache when you start to modify more heavily
Chris
Chris
well, you still need to get those parts above I mentioned, except a 2nd 02 sensor. What you want to do is please your engine harness...you're still going to use an OBD2 engine harness.... I mean, you have to since you own an OBD2 equipped car. The only thing the conversion harness will do is change the ecu you will be using..that's it.
You'll have to keep these things all 96+ (OBD2) B-series:
- distributor (for sure)
- injectors (fo sheezy)
- alternator (fo sheezo)
...once you run all those, your engine harness will like you a lot more as will the engine.
If you need a harness, I have them in stock. Best prices, All brand new OEM pieces. Warrantied. FedExed insured shipping with a candy treat for yo kiddies.
See sig. Do a search for me or email me for further Q's
Turbo_EK @yahoo.com
Turbo_EK @yahoo.com
sleepy_hatch
03-28-2008 10:37 AM
bboylito
05-02-2005 07:34 PM
