b16 into a del sol.. looking for advice and search is not giving me any help
Hey guys. What will I need to bolt a b16 into a 92-95 delsol? are the motor mounts the same or do I need dohc vtec units from the usdm car? how about wiring? I think I can use the stock wiring and just run the missing wires.. Is that right?
Re: b16 into a del sol.. looking for advice and search is not giving me any help (Overblown-Teg)
I have a 95 del sol and i swap a ls/vtec swap in..It's basically the same as the b16...You'll use the del sol top engine mount, tranny mount, and rear mount...You'll need a gs-r side trans mount and 95 del sol vtec a/c bracket mount...The wiring is the same and all you need to do is add the vtec wires, vtec oil pressure switch wires, and knock sensor(p61 or p30 ecu)....Have fun and I hope that help..
Re: b16 into a del sol.. looking for advice and search is not giving me any help (lsvtecracer)
thanks that does help. When you say a del sol vtec ac bracket.. I thought even the base delsol was sohc vtec. I assume you mean the dohc vtec right? What will I need for axles? I have found good information on hasport and hybrid but I am trying to get a complete price figured out before I start.
You can also use these mounts from a 94-01 integra:
- front tranny mount
- rear engine bracket (black T shaped mount)
- A/C mount
- complete axles w/intermediate shaft
You'll have to look for a DOHC DELSOL B-series shift linkage as well! they're designed differently than the Integra shift linkages.
- You can retain your SOHC top tranny mount; its compatible with any B-series hydro transmission.
- you can also retain your existing delsol engine harness; kudos if you own an Si/SOHC VTEC delsol too, that engine harness is perfect to use.
Re: b16 into a del sol.. looking for advice and search is not giving me any help (Katman)
Katman thanks. Are you the same katman from jdmhondaparts? I am planning to get the swap from you.
no problem and yes I am the one and only Katman from JHP
cool, please contact Sheng or Hugh if you plan to purchase a motor, I don't quite sell product for JHP, just provide the ECU reprogramming services.
ATrin
12
07-22-2006 08:47 AM
Integra_Boi
05-08-2004 07:26 AM
Sliced Beard
03-26-2004 02:36 AM
