00Si/LSVTEC wiring into a 96 hatch HELP
Hey i posted this in tech and got no help, so hopefully someone here can help me out. I thought the 99/00 si harness and ecu would work but i found out they don't, so now can't i modify my dx harness with some of the plugs from the si harness to make it work? I got a 97GSr ecu . So if anyone knows what all i have to splice and extend, let me know i need to get my car running. Thanks
Re: 00Si/LSVTEC wiring into a 96 hatch HELP (driftinHatch)
if you use the 97 gsr ecu then you should still beable to use your stock harness and just add your extra wires
[Modified by prawjEKt Cx, 8:02 AM 11/18/2002]
If you are using a 97 GSR ECU, then use your stock harness. You'll need to use the Si harness for a few plugs. All you need to do is run your own wire from the sensor directly to the ECU for all the missing sensors.
savestheday13x2
16
02-01-2005 06:36 AM
not so civic
08-22-2002 01:03 PM
