1st gen b16 in eg
1st gen b16 in eg
did search. just making sure what i need. obd1 distributor,injectors,harness. anything else? this will go in my friends 92 vx. which ecu would be best?
TIA.
TIA.
Re: 1st gen b16 in eg (ahcjar103)
i'd get a throttle body with obd1 map sensors for cleanliness sake. otherwise you should be good to go.
Re: 1st gen b16 in eg (hondaeg5)
TIA.
TIA.
- 4-wire 02 sensor
- thermostat temperature housing w/ integrated thermo-sensor as seen here:
- hydro b-series tranny, unless you're using a hasport hydro-cable kit.
- You can use any of these ecu's to power your engine: a JDM or US OBD1 P30, P61-GSR (B17A ecu), P72-GSR, P08/P28/P29/P70 --> all of which would need to be reprogrammed for DOHC VTEC use.
- as for the MAP sensor, its best to get the newer style (92+) throttlebody w/top mounted MAP sensor...but...you could retain the older vaccum-line style TB. Just make sure you have the right vaccum port going to the firewall mounted MAP sensor as seen in this pic (my fingers are holding up the MAP-vaccum line):
Re: 1st gen b16 in eg (Katman)
can i use the ls o2 and harness then just run the vtec,knock sensor wires. where do i get that thermostat temp housing from? my friend currently has the same setup as me but he found a 1st gen longblock for a good price. by the way thanks,youre the MAN! LOL.
good luck
mynameizstitch
10-05-2009 07:05 PM
