Doin a h22a swap into a 92 civic sedan
i need as much help as possible!! i have never done a swap before so i need as muck help as possible first i will probibly get the swap from osaka, will they give me everything i need? which is better the 93 h22a or the 97 h22a? which motor mounts should i get? will my power steering still work? not to worried about ac prob. take it out, live in Minn. dont cha know will i need the whole lude shifter? any help will be most appreciated! even the smallest thing. my email is badboyben9999@yahoo.com if you guys can send me anything. thanks alot!!!
Re: Doin a h22a swap into a 92 civic sedan (Btothe3rdDegree)
wow if uve never done and if you dont have time to learn, then do this. Send the harness to hasport, and get there mounts too, although with the Place Racing mounts you dont need to cut out your pasenger side mount. The linkage is *** easy to cut, just need a decent cut off wheel. Just measuer the box and cut right in front of those two holes that recive a 10mm for the old stco shifter. U will need a holesaw that is big enough to get the linkage through the firewall. When you make this cut make sure you dont cut anything important on the other side. I
ts an easy swap. dont worry if you want to wire it i can send u a basic wiring diagram
beyond305
12-29-2012 03:15 PM
thevtecnician
01-06-2004 06:23 AM
