which throttle cable and heater hoses? 2000 B16a2 into a 96 civic.
like thet topic says! do i have to use Si throttle cable and Si heater hoses. For 2000 B16a2 into 96 civic EX. Thanks.
Re: which throttle cable and heater hoses? 2000 B16a2 into a 96 civic. (SiR831)
You can use the stock throttle cable, just need to mount the bracket on the intake manifold to hold it in place.
as for the heater hoses, i believe you should be able to use the stock hoses, if not, get 99-00 Si heater hoses and they will align exactly the same.
HT's Biggest Loser
Re: which throttle cable and heater hoses? 2000 B16a2 into a 96 civic. (poison)
yeah, u can make a pracket, its easy, and u need to use the 99-00 Si radiator hoses, and u should also use a dual core SI radiator also, otherwise your hoses may mushroom after a while, but thats just me, i always change em after a swap. good luck
Re: which throttle cable and heater hoses? 2000 B16a2 into a 96 civic. (SIXTYdashONE)
Ya i got the SI radiator hoses but i was talking about the heater hoses? Are the sohc ones long enough or do i have to use the Si ones? What throttle cable did you use in your 97 coupe?
HT's Biggest Loser
i think the heater hoses are fine, i dont recall changing em, im 95% sure there fine, and as for the throttle cable i used in my 97, i used the stock one and used a homemade bracket (just an extension plate), if u need any more details, hit me up, good luck
I used the 99-00 Si cable, and the SI cable bracket that mounts to the shock tower for my swap (I got all that stuff with my swap though). For the price of a cable, it is worth getting the right one. I think I used the Si heater hoses. The hook up to the heater valve was a little weird though because the firewall changed in 99, so I had to bend the valve bracket a little to keep the hoses from rubbing the heater valve linkage. Definitely use the Si radiator and hoses. Good luck.
jadugartir
11-17-2005 03:42 PM
runitup
11-27-2003 12:16 PM
