jdm engine question
Old Nov 16, 2003 | 04:08 PM
95 civic's Avatar
Default jdm engine question
i just wanted to know if a jdm b16a or b18c1 are smog and carb legal in califorina and if they are not is there a way to make them? thanks in advance
ismael
Old Nov 16, 2003 | 11:07 PM
Maximus's Avatar
Default Re: jdm engine question (95 civic)
The only way to pass a jdm engine would be to install 2 or 3 cats onto the car. The emissions regulations in japan are that different, plus its an old abused motor.
Old Nov 17, 2003 | 12:18 AM
eyeamvic's Avatar
A good majority of the engines that come from japan are under 40k miles. They're much more strict on emissions over there. But then agian, they probably beat on the engine while it's still under 40k miles. I think in cali, make sure the engine is newer than the car, and don't forget to wire up the evap solenoid and stuff. That helps with emissions a good deal.
Old Nov 17, 2003 | 06:36 AM
95 civic's Avatar
Default Re: (eyeamvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eyeamvic &raquo;</TD></TR><TR><TD CLASS="quote">A good majority of the engines that come from japan are under 40k miles. They're much more strict on emissions over there. But then agian, they probably beat on the engine while it's still under 40k miles. I think in cali, make sure the engine is newer than the car, and don't forget to wire up the evap solenoid and stuff. That helps with emissions a good deal. </TD></TR></TABLE>
how certain are you about that? becuz i dont want to waste all that money and all the time and find out it wont pass the smog
ismael
Old Nov 17, 2003 | 09:26 AM
APEX CRX's Avatar
Default Re: (95 civic)
you should do a search because it has been really talked about on alot of the boards. but here's a quick run down from a Ca smog ref I talked to
Motor must be an equivalent motor to a USDM motor. example JDM B18c1 is ok because the same motor was sold here.
USDM ECU and all smog sensors have to be used for the corresponding motor
Motor has to be wired the same as the USDM motor- 94-95 OBD1 / 96^ OBD2
NO B16A1's cuz they were never sold here in a USDM car.
Old Nov 17, 2003 | 10:54 AM
wickedEFguy's Avatar
Default Re: (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">you should do a search because it has been really talked about on alot of the boards. but here's a quick run down from a Ca smog ref I talked to
NO B16A1's cuz they were never sold here in a USDM car.</TD></TR></TABLE>
your actually wrong about that. The civic del sol VTEC came with a B16. What you can do is find a chipped P28 or USDM P30 to convert to OBD1 and have all required sensors and exhaust then have a refere and you should be able to pass
Old Nov 17, 2003 | 10:59 AM
95 civic's Avatar
Default Re: (wicked B16)
what sensors do i need
ismael
Old Nov 17, 2003 | 11:11 AM
same sensors that came on the B16 in the del sol. so pretty much the same sensors that come on the PR3/PW0
Old Nov 17, 2003 | 11:28 AM
APEX CRX's Avatar
actually I'm right. I meant no B16a1 motors, there were never sold here. A b16a3 on the other hand was since like you said there were in the Del Sol's and the Civic Si's.
Also unless you get a really lazy Smog Ref which I doubt. You need to run the CORRESPONDING ECU to the same motor. Meaning no P28's
This is INFO I got directly from a SMOG REF in order to pass and get that nice BAR sticker.
Old Nov 17, 2003 | 11:57 AM
95 civic's Avatar
thanks for all your help, it is very useful if there is anymore post it
thanks
ismael
Old Nov 17, 2003 | 11:59 AM
APEX CRX's Avatar
no problem. I'm in process of doing a B18c1 USDM motor swap into my 89 CRX Si. I'll let you know how it goes when I go see the Smog Ref
Old Nov 17, 2003 | 12:02 PM
95 civic's Avatar
kool thanks
ismael
Old Nov 17, 2003 | 12:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">actually I'm right. I meant no B16a1 motors, there were never sold here. A b16a3 on the other hand was since like you said there were in the Del Sol's and the Civic Si's.
This is INFO I got directly from a SMOG REF in order to pass and get that nice BAR sticker. </TD></TR></TABLE>
yeah I just owned myself just didn't read the whole question, LOL
I was talking about converting to OBD1 using a 1st gen B16 using a P30 or a P28.
Old Nov 17, 2003 | 12:56 PM
APEX CRX's Avatar
yeah ya gotta own yourself once in awhile LOL !!!! if this wasn't California swaps would be so much ****'in easier !!!
Old Nov 17, 2003 | 07:06 PM
Dashu's Avatar
JDM ITR motor will not pass CA smog? My car is 2000 EK and JDM ITR 99 motor... I will get more difficulty to get pass the smog. How I can pass the smog?
Old Nov 17, 2003 | 07:09 PM
VTECVillain's Avatar
Default Re: (Dashu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dashu &raquo;</TD></TR><TR><TD CLASS="quote">JDM ITR motor will not pass CA smog? My car is 2000 EK and JDM ITR 99 motor... I will get more difficulty to get pass the smog. How I can pass the smog? </TD></TR></TABLE>
Get another motor, from a 00-01 Integra. Other than that, good luck.
Old Nov 17, 2003 | 07:51 PM
Maximus's Avatar
Default Re: (Dashu)
Like I said above install 3 cats to lower the emissions. As long as its not a Test Only center in CA the smog people won't say anything about the motor in there. You just need the computer to think its smog legal.
Old Nov 17, 2003 | 10:18 PM
95 civic's Avatar
Default Re: (Maximus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maximus &raquo;</TD></TR><TR><TD CLASS="quote">Like I said above install 3 cats to lower the emissions. As long as its not a Test Only center in CA the smog people won't say anything about the motor in there. You just need the computer to think its smog legal. </TD></TR></TABLE>
lol
Old Nov 17, 2003 | 10:29 PM
APEX CRX's Avatar
wtf? 3 catalytic conv. ?
Old Nov 17, 2003 | 10:39 PM
Maximus's Avatar
Yeah 3 cats to lower the emissions on the car. Install cat after cat after cat, its not that hard. That is what a customer at Dohc Garage had to do inorder to pass his test.
Old Nov 18, 2003 | 08:29 AM
vtecb20coupe's Avatar
B A N N E D
shoot, i really hope tx doesn't come up with the same crazy emissions rules as ca currently has. guess we can all have our fingers crossed when the legislation gets passed.
Old Nov 18, 2003 | 10:01 AM
cletus's Avatar
wow that sucks...my car is registered in dawson county ga and we have no emmisions...hehehehe so my cat is coming off very soon
Old Nov 18, 2003 | 10:07 AM
DxTrix's Avatar
Default Re: jdm engine question (cletus)
I had a budy passing a h22 in a 92 eg and all he did was get all the smog legal bolt on crap, cat, 2.5 pipeing, some kind of muffler, usdm ecu, and his motor is newer then his car.
Old Nov 18, 2003 | 11:32 AM
92b16vx's Avatar
http://www.arb.ca.gov/bluebook/bb03/toc.htm#vc
You can research the matter for yourself, here is the info, have fun sifting through it all. But yes, replacement engines from Japan are perfectly legal, as long as they are from the same emissions teir, and conform to US smog regulations.
SRd240sx
Northern California
Jun 1, 2016 03:51 PM
SOHCthiz
12
Sep 13, 2006 11:20 PM
skivik
Nov 29, 2004 02:46 PM
Braco11
Aug 21, 2002 12:44 PM
comptechgsr
Jul 20, 2002 10:10 AM
