CTR N1 Crank Pulley Belt!!
New User
i've searched but there really wasn't a definte answer for the belt size. people are saying...
1)goodyear belt size #: 4pk735
2)acura TL part#: 56992-P1R-004
3)94 acura vigor part#: 56992-PV0-003
4)Gates 745mm NAPA part #: 25-70737
5)belt size 785mm
6)belt size 736.6mm
someone who actually did this mod know which belt size it is? Also, will the pulley need to be balanced?
Modified by Unjockable at 5:24 PM 11/23/2003
5)belt size 785mm
6)belt size 736.6mm
Re: CTR N1 Crank Pulley Belt!! (LsVtec92Hatch)
I just went through the same thing and I believe I used a 29in. belt from Autozone.
When you first try to put it on it don't look like it will fit. but put the belt on the crank then on the alt. and turn the crank till it goes on. As far as the balancing I wouldn't think so being a Honda part!
Re: CTR N1 Crank Pulley Belt!! (Unjockable)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unjockable »</TD></TR><TR><TD CLASS="quote">29 inch = 736.6 millimeter??</TD></TR></TABLE>
Yes
Yes
R91Si
02-11-2004 05:07 PM
MattD@Stoptech
07-30-2003 09:36 AM
