gsr compression
Old Nov 20, 2003 | 03:42 PM
ddong2lee's Avatar
Default gsr compression
im going to do a compression test on my recently swapped gsr...
i was wondering what the compression is for a stock gsr so that i can compare?
yes i used the search and found nothing except for modified gsr's compression results...
thanks...
Old Nov 20, 2003 | 04:08 PM
BrownGSR's Avatar
Default Re: gsr compression (ddong2lee)
190-210 should be good across the board.
Old Nov 20, 2003 | 04:56 PM
eyeamvic's Avatar
Just do the compression test and there shouldn't be any drastic change from the #'s you get in each cylinder. It shouldn't be +/- 20 from each other. Should be around 200 though, there's really no exact number.
Old Nov 20, 2003 | 06:08 PM
ddong2lee's Avatar
dang...numbers are varying...
i did some search on other forums and stuff..
ive got numbers from 170 to like 220...
i dont know whos right or whos wrong...
i guess ill do the compression test and see if you guys think its ok...
Old Nov 21, 2003 | 04:26 AM
ddong2lee's Avatar
Default Re: gsr compression (Manuel)
yea..its a USDM 01 motor with about 16k miles but the guy who had it originally beat on it...so thats why im checking the compression...thanks guys...
ill post up numbers and see what you guys think
Old Nov 24, 2003 | 06:53 AM
ddong2lee's Avatar
hmm..just did a compression test this weekend...
according to the numbers u guys have put up...i have a pretty low compression...
ive got ~170, 180, 180, 180
not sure what i can do to bump it up...
Old Nov 24, 2003 | 09:25 AM
doublejz's Avatar
re-ring it
East
Aug 11, 2009 03:55 PM
blueintegra
Apr 8, 2008 05:40 PM
speedymon
Jan 10, 2003 08:02 AM
Norcalstoppy
Nov 21, 2002 12:55 PM
Slick GS-R
Apr 23, 2002 04:33 PM
