b18b1 swap questions
i purchased a b18b1 form a 97 ls, well, it didnt have exhaust/intake mani's with it so I was looking into grabbing some stock ones for cheap...my question is, will a 95 ls manifold fit fine? also, i need a dizzy, can i just the one from my old engine(b16a3) and can i use the exhaust manifold also?
thanks
Joe
thanks
Joe
Re: b18b1 swap questions (wants_a_sol)
All B18A/B intake manifolds have the same bolt pattern, so you can use a 91 Integra LS intake manifold on a 99 LS motor. The sensors on the manifold will be different, but the bolt pattern to put the manifold on will be the same. Same with the exhaust side, but you can use ANY B-series exhaust manifold as they're all the same (even DOHC VTEC). For the distributor, you'll need the Integra LS so it'll bolt onto the LS head (w/out having to cut anything). Of course, depending on the year of your car and what OBD you are planning on running, the plugs and sensors will vary.
obviously obd-1 or i wouldnt have asked about a 95 mani and the fact its going in a 95 sol i thought all 92-95 honda/acura's were obd-1 anyway???
would an obd-1 PR4 ecu work? also, what needs to be done to the vtec dizzy to have it work on the ls head? cant find the right dizzy that im not going to pay an arm and leg for
yet again, i did find a dizzy from a 92 ls, would this work or would i have to wire anything differently(going into obd-1 car)
!!!!! anyone?
i need to know if an obd-1 pr4 ecu will work and what needs to be done to the dohc vtec dizzy to make it work on the ls head or if a dizzy from a 92 ls would work without having to rewire anything???????
