b18C clutch problems.
Old Nov 14, 2003 | 08:05 AM
thehatchninja's Avatar
Default b18C clutch problems.
I've been having trouble getting my car into gear. I can push the clutch pedal in, and it's like it's not in at all. Sometimes i can bleed the clutch and it will be fine for an hour, week, day....whatever....it's very sporadic. But it's getting worse. I thought it was a clutch master cylinder problem since it did the same thing with the old motor. So the cluctch m/c was replaced, and now i'm suspecting the slave cylinder, but that's what was replaced on my old D16z6 with the same problem and it didn't fix it. I really don't know what to do. Any ideas.
p.s. when it's working the clutch grabs awesome, with no slippage.
i'm gonna post this in the tech section too...no flaming
Old Nov 14, 2003 | 09:16 AM
doublejz's Avatar
Default Re: b18C clutch problems. (thehatchninja)
slave cylinders usually go before master cylinders, i would replace your slave cylinder (would have done that first off, cheaper then a master) and then check all your fittings to make sure there tight and not leaking. There isn't much to a clutch line (master-line-slave) its probably your slave though
Old Nov 15, 2003 | 08:29 AM
Default Re: b18C clutch problems. (doublejz)
i have 2 d-series slave cylinders....i think one has 70K miles on it.....should i try that....i know their interchangeable, and i don't have ANY money right now...not even $40. (I'm a college student, i ramen)
Old Nov 16, 2003 | 05:34 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">i have 2 d-series slave cylinders....i think one has 70K miles on it.....should i try that....i know their interchangeable</TD></TR></TABLE>
They aren't hard to change and since you already have them, why not give it try?
Old Nov 17, 2003 | 12:41 PM
Default Re: b18C clutch problems. (VTECVillain)
bump....anyone had this problem before?
Old Nov 19, 2003 | 03:27 PM
help!
Old Nov 19, 2003 | 05:32 PM
doublejz's Avatar
Default Re: (thehatchninja)
you change your slave cylinder yet?
Old Nov 19, 2003 | 05:39 PM
Audipwr1's Avatar
Default Re: (doublejz)
always good to replace BOTH master and slave
slave goes first, but when you put on fresh slave it blows out the master
70k intervals are usually what they last
Old Nov 20, 2003 | 03:41 AM
doublejz's Avatar
Default Re: (Audipwr1)
no offense Audipwr1, in the first post, he mentioned he had already replaced the master cylinder
AmbitionHONDA
Mar 4, 2013 03:58 AM
Miracle11
Feb 13, 2011 06:38 PM
Black '97 GSR
Jan 10, 2006 06:20 PM
integra3586
Oct 30, 2005 09:20 PM
SloCivicHMM
May 12, 2003 01:57 PM
